Mid-west garage sale. Turbo, trans, susp, wheels, lots more
Finally got around to cleaning out the shop and came across alot of parts I no longer need. All parts are OBO so make some offers, low ballers welcome!!!
-17x7, 5x100 ADR sokudo wheels with Bridgestone potenza tires. Two of the four wheels have some curb, one with mojor curb and scuff, two of the tires are also requiring replaced (($350 OBO))
-set of four fat fives with center caps, very little curb but also very clean (($220 OBO))
-only 3 yoko something 17x7, 5x100 wheels, some curb with bald tires (($75 OBO))
-t3/t4 garrett turbo 4 bolt exhaust side, 57 trim, .60 A/R, b series cast turbo manifold, and turbo oil feed line. the turbo held 10 pounds of boost but should be rebuilt (($200 OBO))
-DSM injectors (440cc I believe) (($50 OBO))
-OBD2 b16 ecu (b16a2) (($75 OBO))
-OBD0 d16a6 ecu (pm6) (($50))
-OBD1 d15b7 ecu (p05) (($20))
-RS-R catback exhaust, eg/ek hatch (($250 OBO))
-stock del sol exhaust with cat (($60 OBO))
-GSR flywheel, needs resurfaced (($20 OBO))
-d series flywheel, ready to go (($30 OBO))
-exedy OEM replacement clutch w/ pressure plate for d series (($50 OBO))
-EF hatch headlights (($20 OBO))
-EF engine harness non-vtec, (($20 OBO))
EF hatch body harness non-vtec ((40 OBO))
-b16a2 block with main caps and oil squirters, was honed but should probably be done again (($50 OBO))
-d15b7 short block (($50 OBO))
-b16 hydro trans with vss and reverse sensor; very slight grind into 3rd, otherwise no problems (($350 OBO))
-2x d series transmissons; the J8F has no grinds while the C5B I am unsure about (p20, came out of a cx) (($40 OBO for J8F, $20 OBO for C5B))
-stock d series header, no heat shields or 02 sensor (($10 OBO))
-stock b series header with heat sheilds and no 02 sensor (($20 OBO))
-obd1 vtec IM, TB, Fuel Rail, Injectors, sensos (($40 OBO))
-obd1 non vtec IM, TB, some sensors (($10 OBO))
-eg front brakes, two good calipers; one of which has less than 500 miles, one good rotor (($20 OBO))
-Tein super street suspension with top hats and dampening for 00-05 eclipse, less than 1k miles on them with moog sway bar end links. BUY IT FOR YOUR GIRL FRIENDS ECLIPSE! (($800 OBO))
^^I think I sucked up a rock or something hard, obviously lol; thats what you get for not screening you turbo inlet I guess!!
I'm sure some guy just raped it when i left my car parked alone in the ihop parking lot at 3am from a long night of playing some intense halo!!!
hello there i would like to buy the engine harness you have for sale let me know if oyu do still have it i will send you the money via paypal thank you you can contact me at 214-710-9319 if you would like too
