Changing wheel bearing on 88 hatchback
Old Aug 22, 2002 | 08:01 AM
Erik_Pb_Foot's Avatar
New User
Default Changing wheel bearing on 88 hatchback
I have a bad wheel bearing on my right front and have already bought the replacement from Advance Auto, now I'm ready to install. Can anyone point me in the right direction before I try this blind folded? I'm sure there isn't much to it but I want to know what to expect and how long it -should- take me. Thanks a lot
-Erik
Old Aug 22, 2002 | 08:12 AM
wronghand's Avatar
Default Re: Changing wheel bearing on 88 hatchback (Pb_Foot)
Your best bet would be to pull the hub and take it somewhere to be pressed.
Old Aug 22, 2002 | 09:29 AM
New User
Default Re: Changing wheel bearing on 88 hatchback (wronghand)
I have a press in the garage so that won't be as much of an issue as i had thought it may be. I'm just in need of someone to give me an idea of how long this should take to do it yourself and what kind of problems i should expect. thanks
-erik
Old Aug 22, 2002 | 09:45 AM
Tyson's Avatar
just make sure to have a good assortment of collars and plates to press the right part of the bearing. taking the knuckle off should take less than 30 mins, then pressing it in and out another 30 mins and then another 30 mins to put it all back together.
Old Aug 22, 2002 | 10:07 AM
Hunter's Avatar
erik, knowin' u, i don't think this is gonna be a do it yourself deal
Old Aug 22, 2002 | 10:28 AM
wronghand's Avatar
The one thing I remember my buddy running into on mine was the seperating the hub from the bearing. The bearing came apart and it was a real bitch to get the racer off of the hub.
Old Aug 22, 2002 | 09:56 PM
New User
I'm pretty confident I can do this myself. After all, I own a small assortment of Snap-On tools and you know that qualifies me.
But all in all, I'm gonna give it a try tomorrow night. I'll let you guys know how it works out.
-Erik
Old Dec 26, 2002 | 07:56 PM
my_slow_civic's Avatar
Would you take the whole hub in? Or would it need to be seperated more? I need to replace mine soon too.
Alosm how much does the new bearing cost? Anyone know off hand?
Old Dec 27, 2002 | 05:19 AM
keithv's Avatar
Default Re: Changing wheel bearing on 88 hatchback (sirk)
just bring the whole knuckle to the machine shop tp be pressed.
and according to http://www.hondaautomotiveparts.com, the bearing is $58. i would think napa/autozone/advance auto/etc. would have a cheaper price for their bearing.
Old Dec 27, 2002 | 10:05 AM
CRX-RX's Avatar
Default Re: Changing wheel bearing on 88 hatchback (breaka_1_9)
Actually, most of the autoparts stores are right around the same price, and use the exact same part that honda/acura sells. Of course there's still no replacement for OEM.
Old Dec 27, 2002 | 10:41 AM
shorti's Avatar
Default Re: Changing wheel bearing on 88 hatchback (CRX-RX)
is a rear wheel bearing exactly the same as a front bearing?
like is it harder to chage or easier?
Old Dec 27, 2002 | 10:43 AM
MADEINIRAQ's Avatar
i had this problem too on mine.. i just used a cutting torch and cut a slot in the race and it popped open and slid right off the hub.
Everybody should have torches. they are your best friend
slowly slipping away
May 5, 2007 07:45 AM
FakeJDMEF8
18
Nov 22, 2005 08:13 PM
Tuesdaynightfever
Apr 16, 2005 06:29 PM
yung98gsr
Feb 18, 2005 09:28 AM
Elkins911
Jun 15, 2003 02:29 AM
