What's this?
Old Jul 5, 2009 | 09:57 PM
Ej8_KiD's Avatar
Default What's this?
So i removed all my ac components from the bay , hardlines , compressor etc. and these two boxes from under the dash which i dont know what the hell they are called
but there is still this one right on the middle of the dash , do i need to take out that one too and plug the heater hose outlets on the fire wall?
Old Jul 5, 2009 | 10:01 PM
WickedKP's Avatar
Default Re: What's this?
the one in the middle is your heater core for youe heater.
are you just trying to remove your a/c and keep the heater.
or just screw it all and not have heat or a/c
cause if your planning to keep heat you need to put back in your blower motor.
and get the following parts.
79810-SR3-A01 heater duct.
91631-SR3-000 firewall plug without a/c
and couple plug to to plug up the hole your no long use on the firewall for the a/c
Adam_b16a's Avatar
Whats your purpose? Are you just removing the a/c and heat?
*EDIT* ^^ beat me to it.
Old Jul 5, 2009 | 11:23 PM
Ej8_KiD's Avatar
im planing on keeping the ac nor the heater so i can take that one too right?
Old Jul 5, 2009 | 11:26 PM
buymesomedunks's Avatar
those are some bomb *** pictures haha
Old Jul 6, 2009 | 05:34 AM
Since 1983's Avatar
in your first picture the box on the right is the blower motor, the bow on the left is your AC stuff, in the 2nd picture the bow thats still in the car is the heater core, if you plan to have heat still they need to be in the car, if your really **** about shedding weight you can take the AC box apart and pull the nonsense out of there.
Old Jul 6, 2009 | 08:56 AM
rick_rabies's Avatar
I'm not Rick!
what kind of camera do you have?
Old Jul 6, 2009 | 09:49 AM
Ej8_KiD's Avatar
Im taking all my ac and heat out so i wont be needing that.
Rick , i have a nikon d40
Old Jul 6, 2009 | 11:13 AM
I'm not Rick!
nikon d40. sweet thanx. im buying a new camera YAY!
Old Jul 6, 2009 | 07:07 PM
WickedKP's Avatar
Yeap. If u don't care for heat or a/c then u can remove it. just make sure the heater hose coming from the engine is looped back or plugged up.
Old Jul 6, 2009 | 07:41 PM
Ej8_KiD's Avatar
gotcha , what about the hole in the firewall , is there a grommet i can use to seal up that hole? i might run my wire harness through that opening si ima need a grommet of some sort
Old Jul 6, 2009 | 08:00 PM
95EG690022's Avatar
No S*** can you take some pics of my car after ur done with ur A/C? haha
Old Jul 6, 2009 | 08:15 PM
Murk 'EM's Avatar
if your doing this to shed weight your doing it kinda backwards.. why would you go thru the trouble of ripping appart your dash and having to plug up holes when you can take the carpet out and get rid of the sound **** on the floor (JUST a couple lbs there)
the dash was the last thing i did in my tear down
Old Jul 6, 2009 | 08:45 PM
WickedKP's Avatar
what about the hole in the firewall , is there a grommet i can use to seal up that hole? i might run my wire harness through that opening.
Well as i stated above the non a/c plug can be found at your local honda dealer.
as for the heater core i don't think there was a plug for it. I believe all civic came with heater. I could be wrong.
if you want to run wire through the heater core holes than stop by your local stereo shop they should have wire garment plugs. the same one they use to run power wire through firewall.
I would follow Murk 'EM advice for weight issue, but if it's for something else g/l on your project.
Old Jul 6, 2009 | 09:10 PM
hOnda_hiEn's Avatar
anyone know if those hardlines and stuff will all fit in an EG.,? if so.. are you selling those ej8kid?
Old Jul 6, 2009 | 10:24 PM
Ej8_KiD's Avatar
if they fit , they are urs.
Well i aint doing it to save weight , im doing a full tuck and re-spraying the bay and such so , im not gonna run P/S or A/C
Old Jul 6, 2009 | 10:25 PM
Ej8_KiD's Avatar
haha , sure bro if u only lived closed lol . im always taking pics
check out my flickr
http://www.flickr.com/photos/dvalentin/
Old Jul 9, 2009 | 07:25 AM
I'm not Rick!
i looked up that camera and its $1000!! whatthefrick. how much did you pay for yours?
i saw a 6mp for 500 and the 12mp for 1200. thats crazy for a camera.
Old Jul 13, 2009 | 08:30 AM
Ej8_KiD's Avatar
ok so if i take out the heater core box , will my climate control lights still work?
Old Jul 13, 2009 | 08:36 AM
HDTV's Avatar
look here : http://www.nikonusa.com/Find-Your-Ni...page?pid=25420
Old Jul 13, 2009 | 08:45 AM
I'm not Rick!
oh thanx. all the ebay d40s dont come with lenses
Old Jul 14, 2009 | 09:22 AM
Ej8_KiD's Avatar
Bump . . . anyone?
Old Jul 14, 2009 | 09:27 AM
ej1love's Avatar
yea, i mean leave the harness/plugs for it. i took out that firewall mat too...
thumper64's Avatar
Why would it matter if the lights still work if you have no heat or AC? Why not stick something else in the dash in the place of the climate controls, or shave them or something?
Old Jul 14, 2009 | 09:34 AM
I'm not Rick!
the cd player din i think is the same size you can get a din for the climate control
