wheel rub problem
Old Jul 5, 2009 | 08:58 PM
elliot's Avatar
Default wheel rub problem
i've got an 88 EF with a B18B1 with 14" CRX Si wheels on the front with 195/60/14 tires. i just got the car about three weeks ago but recently (as in, a week or so) the front wheels have started to rub. the car is lowered on kyb shocks/struts and skunk2 springs so i can't raise it up to see if that helps.
the camber is maad negative. from what little i can see with a flashlight, i can't tell when the car is sitting still what the wheels are rubbing on. when you push the car, you can hear the wheels rubbing but not what on. do you think they are rubbing because of the camber? any help appreciated
ps. it is the front wheels rubbing, not the back ones
Old Jul 5, 2009 | 09:10 PM
BiG ChOr!Zo's Avatar
Default Re: wheel rub problem
jack up the front wheels and see what its rubbing on...if not get yourself a set of coilovers and let me have the springs
Old Jul 5, 2009 | 09:11 PM
elliot's Avatar
i have already jacked it up and looked and i see some places that look rubbed, but when i set it back down, the tires arent touching them, so those places only get rubbed in turns, not straight driving.
i'll trade you coil overs for springs
Old Jul 5, 2009 | 09:13 PM
send pics and specs of them coilovers
Old Jul 5, 2009 | 09:17 PM
elliot's Avatar
lol i meant i'll trade my springs for some coil overs not the other way around
guess i'll just get a front camber kit and see from there
Old Jul 5, 2009 | 09:23 PM
i got cheap coilovers on the front and sportline springs on the rear...if you want to trade springs for springs since mines might be a little bit higher than yours...i dont know the drop but this is the way they look on my car when i had all 4 of them on...!!!
Old Jul 5, 2009 | 09:33 PM
elliot's Avatar
this is mine
Old Jul 6, 2009 | 02:42 PM
johnnyonth3spot's Avatar
Put your car on jackstands and put a jack under your lower control arm jack that up turn your wheel and check clearances
jeresaur
Aug 10, 2011 02:27 PM
thorclark
Nov 13, 2008 07:36 AM
hndasiguy
Honda Civic (2006 - 2015)
May 28, 2006 05:38 PM
mikeunreal
Suspension & Brakes
Nov 22, 2005 08:16 PM
99civic_exSB
Apr 24, 2002 04:42 PM
