Rev?
Old Aug 22, 2002 | 06:28 AM
Hondasaurs's Avatar
Default Rev?
I just put a cold air intake on my car. Now my engine revs up to 1500 and drops down to 800 when sitting still. What is causing this and what can I do to fix it?
Old Aug 22, 2002 | 06:40 AM
EF_LSVtec's Avatar
Default Re: Rev? (ZC_CRX)
Did you attach that little vacuum hose that goes to the CAI arm? Make sure all your hoses are attached as it was, if not plugged.
Hondasaurs's Avatar
Default Re: Rev? (EF_LSVtec)
I have the hole on the CAI plugged. Should I run the line?
[Modified by ZC_CRX, 10:41 AM 8/22/2002]
Old Aug 22, 2002 | 06:42 AM
USDM 4G VTEC's Avatar
did u reset the ECU after installing the CAI.???
u supposed to reset that baby everytime u do a mod....
try it...
Old Aug 22, 2002 | 06:44 AM
Hondasaurs's Avatar
Default Re: Rev? (JDM EF9)
ok ill try it...thanks
Old Aug 22, 2002 | 08:15 AM
Hondasaurs's Avatar
Still getting the rev up then down...now what?
Old Aug 22, 2002 | 08:46 AM
EF_LSVtec's Avatar
Recheck the hoses that were connected to the old intake arm, make sure they'e connected back to the CAI. There's one at least...
Old Aug 22, 2002 | 08:54 AM
89 CRX SI's Avatar
use a valve cover brether if you plug the hole on the intake arm
Luchini
Dec 28, 2006 11:33 PM
ThinkRevolution
Dec 7, 2006 11:45 AM
Sabbotage
Oct 29, 2004 01:33 PM
Zulu888
Apr 9, 2004 02:54 PM
97ITR
Dec 4, 2001 02:30 PM
