Transmission & Drivetrain Gearboxes, Differentials, Clutches
need help on comp twin disk adjustment
Old Jul 5, 2009 | 04:08 PM
promotor's Avatar
Default need help on comp twin disk adjustment
just installed new twin disk on my drag car,at the track when i shift on gear its like theres a wall blocking my shift 2nd and 3rd when i did an adjustment i just add more freeplay on my clutch pedal like about and 1inch,new master cylinder and sleeve.also when im launching car still moves with the clutch ingage.can somebody help me to properly adjust the clutch or some info about what you guys think is going on.thanks in advance.
Old Jul 5, 2009 | 06:01 PM
hello1320's Avatar
Default Re: need help on comp twin disk adjustment
do u have a pedal stop ,,without a pedal stop sometimes u mash the pedal down to far it wont shift fast check to c if there is any pressure or play where your shift fork touches the slave.
Old Jul 5, 2009 | 06:06 PM
promotor's Avatar
what shift fork are you talking about?do i have to remove the tranny for that?or you mean the shift linkage?
promotor's Avatar
thanks
Old Jul 6, 2009 | 02:47 PM
hello1320's Avatar
the fork that pushes on the throwout bearing it sticks out of the front of the trans
Old Jul 6, 2009 | 02:51 PM
promotor's Avatar
ok i will check that and i will install a pedal stop.just like what other people do weld a not and use a bolt for adjustment.
99hondadx
Feb 10, 2017 05:35 AM
F20B_accord
Sep 5, 2010 07:49 AM
SLAMMEcD7
Mar 30, 2010 07:17 PM
JDM-ish
Jan 20, 2007 05:52 PM
del_parker
Sep 1, 2003 07:17 PM
