oil in spark plug #1-2 not 3-4
ok so i take off the spark plug wires and i see oil in #1-2 not 3-4 its not much just residu but it was never there 2 months ago so it seems its just building up slow
any ideas guys?
any ideas guys?
thats the cause for sure take the valve cover off and pop the old gromets off and replace. The old ones get hard and dont seal and let oil from the head to get under them and into your sparkplug holes
alright soooo spark plug tube gaskets are what i need too replace thanks guys!!!!
one more quik question anyone got a diagram of where my evap canister is? lol
^x2 just inspect it thouroughly before putting the VC back on...ANY cracks or soft spots= replace. If it looks good, just make sure to hondabond the corners and get a good seat.
Exactly, you never know what kind of hidden damage or wear and tear there might be. But then again that's for people who don't want to do double the work.
yes ok sure sure well does anyone have a clue cause i just talked too my brother and my mechanic and apparently from the sounds of this it is a piston ring and none of you have even mentioned that yet because for oil too even get up too my sparkplugs it had too get passed somewhere............... zzzzzzzzzzzzzzz
You can pay them or lesson to us that have all been there.
Order a valve cover gasket set from your local Honda dealer.
Be careful re-tightening the weak old valve cover bolts. they will snap very easily. The gasket seals the oil not the tighteness of the "weak old" valve cover bolts. Get the hint there?
If were wrong you haven't lost that much money and you'd be buying a valve cover gasket set anyway's when your mechanic rebuild's the bottom end. This way here he can reuse them.
Oh yea, put a small dab of silcone sealant on the corners of the gasket by the cam tower (s).
I have no idea which engine you have but here,
http://www.hondaautomotiveparts.com/...DER+HEAD+COVER
when i changed the rocker cover in my 96 sir civic i forgot to put the rubber seals bk in . they just sit under the bottom of the cover and the plugs slide through them. i would check to see if they are ok before spendin time and money on piston rings.
Piston rings? Are you kidding? So, the oil blew by the rings, somehow didn't get burned up in the combustion chamber, and then managed to wiggle through all the threads on the spark plug to end up there? Or are the seals bad on the bottom of your valve cover? Which scenario sounds more likely? Maybe your mechanic missunderstood your situation, if not, you need a new mechanic!!
piston rings?? XD
theres a lot of oil pressure inside the head.
get item 001. thats $31 for the ENTIRE valve cover gasket set. thats not a bad deal. and well worth it.
VTEC_Du_Ma_Mai
Sep 5, 2008 01:41 PM
gixxer6
Oct 29, 2002 01:10 PM
