need more help mpfi swap ahhh lol
ok here the thing my car turns over fine and is get fuel just no spark now im geting power up to the dizzy and the dizzy i have is new just got it from autozone the only code the ecu is flashing is 10 and that the air intake sensor and i knowthat will not cause my car not to start ...SOO i need some help m car been down for like 3 months now and i want to get it runing so any one that can ppoint me the right way will help out alot thanks
i would try switching the 2 white wires at the distriutor around, if not that check the ground for the starter ,its a wire coming from the harness that should be bolted down by the starter with a 10mm bolt.
Did you flip around the white wires on the distributor?
Also try another Distributor, or check to see if the rotor inside is loose or the screw is loose.
why not just try?
take the belt off, put everything in time (crank cam and dizzy)
put pistons 1 and 4 at the top of the stroke
just make sure.... why not? could solve your problem. hondas jump time somtimes.
got that thing runing but now it is reving to high so dose any one know if one of the wires on the tps is a ground because before the car had one set up as ground ?
also could be your eiacv( electronical idle air control vavle) its located on the back of your intake.
ive heard a lot of complints from people after doing something it idles wrong and 90% of the time it ends up being the eiacv.
check that out redo your idle and see if taht fixes it. if your not sure how pm me and ill explain it step by step
G. Man
15
Apr 8, 2011 08:06 AM
DRKSol
10
Jul 3, 2004 02:46 PM
