Will a d16a6 distributor fit on a d15b1?
Old Jul 5, 2009 | 06:58 AM
LS94tegra's Avatar
Default Will a d16a6 distributor fit on a d15b1?
just wondering, I've used the search tab and didn't find anything.
Old Jul 5, 2009 | 09:31 AM
allgo88's Avatar
Default Re: Will a d16a6 distributor fit on a d15b1?
ive tried it.didnt work.it would start,but stall immediately.
Old Jul 5, 2009 | 09:34 AM
dephtone's Avatar
d16a6 has 3 sensors in the ditrbutor TDC, Cylinder position, and crankshaft position sensor.
the d15b1 only have TDC and Crankshaft position sensor.
When you conver tot multiport you have to run 2 wires for the cylinder position sensor. This is why the a6 dizzy does not work on a b1 or b2 motor, because the dizzy has no idea where #1 cylinder position is and doesn't know when to fire, hence why it stalls.
Old Jul 5, 2009 | 10:16 AM
AJxr's Avatar
correct! it bolts up of course but only works and is needed when you do the mpfi swap.
Old Oct 5, 2011 | 03:12 AM
19EF90's Avatar
what about putting in an a6 cam in it would the dizzy work then?
Old Oct 5, 2011 | 04:50 AM
singlecamsaint's Avatar
no if your dual point fuel injected your going to need the 5 wire square plug dizzy, its the fuel injection system not the engine internals. its good you have that distributor though, because its one of the main things you need for a multi-port fuel injection swap.
Old Oct 5, 2011 | 05:22 AM
KINGVEM^^ED6's Avatar
Since u have all this **** convert to mpfi swap cams and u will love ur car
Old Oct 5, 2011 | 06:59 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
While this is an interesting theory, it is not Fact. The reason the distributors will not work in place of each other electronically is due to them having different reluctor rings... They send different pulses to the ECU and we just can't have that now can we? They can swap physically though with out a problem. Also, internally "sensor" wise they have the same... you are mistaken when you say it is missing one...
OBD0......OBD1
[b10].......[b11] --- cyp P aka cylinder position
[b12].......[b12] --- cyp M aka cylinder position
[c3].........[b13] --- tdc P aka top dead center
[c4].........[b14] --- tdc M aka top dead center
[c1].........[b15] --- ckp P aka crank position
[c2].........[b16] --- ckp M aka crank position
[b15].......[a21] --- Ignitor signal
Old Oct 15, 2011 | 04:54 AM
19EF90's Avatar
i have an ex so already mpfi and i got it running but am getting code 4 and i tryed to swap the 2 wires,so i know its my crank position sensor so ? would i be able to swap out that sensor with a different dizzy like dpfi or obd1 dizzy also thank you all at this sit i know i am new and do not have alot of posts but i have read alot of yours and got alot of help,so thank you all.
96GS-R-Kaden
May 21, 2008 12:08 PM
wonda
Nov 8, 2004 03:55 AM
TheSaianITR
Jan 17, 2003 04:24 PM
