93 eg wont start
Old Jul 4, 2009 | 07:25 PM
erikwithak's Avatar
Default 93 eg wont start
not getting any spark to the wires cleaned the rotor and cap still nothing
also no power to map sensor
tryed to check codes and the cel light just flashed non stop and didnt come on then start flashing the way it is supposed to like this says also i had a blue clip with the same color wires not a grey one
all this is on a d15b8 and i did a intake manifold swap off of a z6 head putting everything stock back on tomorrow
any help is welcome i need a lot of it haha
PLEASE HELP ive been working on it since 10 this morning SO PLEASE
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Jul 4, 2009 | 09:04 PM
Matt93eg's Avatar
Default Re: 93 eg wont start
Your Ignition Coil probably died.
You can take the Coil and Igniter out of the Distributor and I "think" you can take it to autozone and they will test it. Or if you have a Multimeter you can probably check those items yourself.
Old Jul 5, 2009 | 01:45 AM
Davus's Avatar
Check ignition and may God's love be with you.
... But actually, check fuses and ECU power?
Some day I *will* post a reply with just the first line =[
Old Jul 5, 2009 | 03:49 AM
erikwithak's Avatar
well the coil shocked my buddy yesterday while we were working on it so haha it hink the coil has power just no spark going to get all new stuff today dizzy cap wires plugs and go from there if that dosent work off a cliff she goes haha
bakerash4844
Aug 28, 2012 10:22 AM
Jonathannx2
20
May 28, 2011 12:49 AM
hurleyboarder21
Apr 12, 2004 07:22 PM
93civicex14
Jan 23, 2004 07:53 AM
wanttorace
Oct 5, 2002 10:31 AM
