few a/c removal Q?
Old Jul 4, 2009 | 07:15 PM
ej1love's Avatar
Default few a/c removal Q?
im removing my buddys a/c in his coupe tomorrow, most likely for a few bucks. i know what to take out from under the bay. were gonna pull the dash too, to put a 93 civic dash to have the airbag delete. my question is, what can i take out the dash? or from under the dash. he still wants to have heat. but what else will be dead weight when there is no longer a/c and can be removed?
Old Jul 5, 2009 | 12:17 PM
ej1love's Avatar
Default Re: few a/c removal Q?
so theres nothing inside the car to take out?
Old Jul 5, 2009 | 12:31 PM
iliv2xlr8's Avatar
I would try to convince him to keep it.....
As far as removing, the condenser, compressor and the lines. There is nothing under the dash.
Old Jul 5, 2009 | 12:33 PM
ej1love's Avatar
im gonna make some $ removing it and he has another car, this is his beater. thx for the info...
Old Jul 5, 2009 | 12:44 PM
iliv2xlr8's Avatar
Right on.
GL OP
Old Jul 5, 2009 | 09:46 PM
Ej8_KiD's Avatar
there are some stuff under the dash also
Old Jul 5, 2009 | 10:22 PM
CuryFeritEk's Avatar
Do u want to sell the complete a.c.
Old Jul 5, 2009 | 11:49 PM
the171's Avatar
there are most surely under-dash parts. I just left mine in there because I can't be bothered to take all that apart. But if ur going to remove the dash then whatever. The rest is very easy.
Old Jul 6, 2009 | 03:47 AM
hondamark35's Avatar
False.
if you're wanting to pull out a complete working A/C system you'll need the evaporator and evap housing from under the dash. since your buddy still wants his heat and blower to work afterwards he'll have to replace the evap. housing with a duct (#7) similar to the image below. (i couldn't find the real piece, but it looks like this one...)
if this is just to clean up the engine bay, and remove some weight from the car, then you won't need to worry about these parts as they don't weigh much at all.
Old Jul 7, 2009 | 06:41 PM
ej1love's Avatar
maybe but it might be sold, pm me a price...
Originally Posted by hondamark35
False.
thanks guys...
Old Jul 7, 2009 | 08:10 PM
Jackal6042's Avatar
#45 is the major component under the dash.
you said this was an EG or EJ1 right? just saw the part about adding a 93 dash
Old Jul 7, 2009 | 08:13 PM
Ej8_KiD's Avatar
i just took all my ac stuff out
Old Jul 8, 2009 | 10:43 AM
ej1love's Avatar
its an ej1, and hes gonna keep the dash for now but remove the srs stuff. is there anything under there we can remove? its been raining here. no work done yet...
Old Jul 8, 2009 | 12:22 PM
ej1love's Avatar
also the lines in the front of the car that curve back and mount into the body of the car, can be removed too? like if u look at the car from the front w/out the bumper u should only see the radiator and the header? not the ones that go across there. its rainin bad here so i cant take pics or look and figure it out myself...
Old Jul 8, 2009 | 04:10 PM
Jackal6042's Avatar
Yes all the lines can be pulled. The lines you are talking about will run from the condensor in front of the radiator, along the passanger side of the engine bay and attach to #45 in the picture I posted (firewall just behind the battery)
Wait, here is the perfect picture... Pull all this BS seen below:
#15 kinda hides between the splash guard in the drivers side wheel well and the bumper, but I'm sure you knew that.
Old Jul 8, 2009 | 04:16 PM
Jackal6042's Avatar
hondamark35 mentioned replacing some ducting (#7 in the image he posted).
If you didn't want to go buy parts all you would need to do is somehow seal the whole where #45 in my previous post exits the duct and goes to the engine bay.
Old Jul 8, 2009 | 07:48 PM
ej1love's Avatar
thx thats the pic i BEEN looking for...
in the pic: the piece between #17 and #18, thats behind the firewall; i can pull that and still have heat right? i got everything else out today
Old Jul 8, 2009 | 08:32 PM
Jackal6042's Avatar
The part you mention is behind the firewall (behind the glove box). It is the housing for #45 in my previous picture. Take the housing apart and remove #45 as mentioned but the housing is also ducting so you will need to put that back in the vehicle for the heater to function normally (blow to all the vents). As I mentioned just find some way of sealing the opening in it that goes to the engine bay. Like some plastic cut to shape and RTV that **** in there.
Old Jul 8, 2009 | 08:47 PM
ej1love's Avatar
alright, gotcha. and i can get to that by just removing the glove box? thx again man...
Old Jul 8, 2009 | 08:54 PM
Jackal6042's Avatar
NP, yeah you should be able to get to it with the glove box removed. You will have to remove that metal brace from behind the glove box as well.
Old Jul 8, 2009 | 08:58 PM
ej1love's Avatar
yea thats wat i meant...
y2kferari
Mar 16, 2007 02:12 PM
importracer47
May 7, 2003 06:09 PM
neilff
Apr 24, 2003 09:46 PM
Halive
11
Jul 6, 2002 10:49 PM
