ecu for my si w/d16z6
Does any one know if I can run an obd0 B16 ecu in my CRX to run my sohc vtec. I know it has the same plugs but didnt know if it would throw any codes or even work for that matter. I just dont really want to do the obd0-obd1 change over due to the fact that the motor is only in the car for right now.
The pm6 will work but you will have no vtec. Convert the car to obd1 and run a stock p28 for the engine to run at it's best.
There are some tuners out there that can chip an ECU that is still obd0. If you want to go that route you could also do that.
You're going to need a PS9 ECU to run 1-wire vtec. It's off rare 90-91 EX Sedans.
The nifty things about is that it's pretty much a regular PM6 but it's chipable like the PM6-A09 and it also enables you to run 1-wire vtec without any sort of piggyback or RPM switch.
Si2See
13
May 19, 2005 11:13 PM
Slammd Sol
Mar 24, 2004 07:45 PM
