What makes the gsr brakes better then an eg ex brakes
Old Jul 4, 2009 | 01:27 PM
twiztid_989's Avatar
Default What makes the gsr brakes better then an eg ex brakes
Like the title says what makes the gsr brakes better then an eg ex brakes? i just brought a 4 door gsr for parts and i was wondering whats the different on the brake set up
Old Jul 4, 2009 | 01:38 PM
hushypushy's Avatar
Default Re: What makes the gsr brakes better then an eg ex brakes
Rotors are the same size, but the GSR has different calipers, with a bigger piston inside. The GSR master cylinder may also be slightly larger.
Old Jul 4, 2009 | 01:42 PM
iliv2xlr8's Avatar
Swap them, you will not be disappointed. The MC & booster as well.
SS lines and quality pads.
Old Jul 4, 2009 | 01:59 PM
r the spinnedles the same or r they different
Old Jul 4, 2009 | 02:02 PM
iliv2xlr8's Avatar
Same for EG. All EG and 94-01 Integra suspension will interchange. I simply swapped the spindle and hub assemblies for the front and the entire trailing arm for the rear.
Also a great time to get those GSR swaybars, just need the LCA's too, to bolt them up.
Old Jul 4, 2009 | 02:07 PM
well i have a 94 civic ex sedan w both sway bars. r the gsr just an upgrade for my car
Old Jul 4, 2009 | 02:10 PM
adam00's Avatar
so the gsr and ex have the same size rotors just the gsr uses a bigger caliper? and what about the gsr brakes compared to dx brakes?
Old Jul 4, 2009 | 02:26 PM
92eg_h22's Avatar
gsr suspenion is great....i love mine.
Old Jul 4, 2009 | 02:28 PM
K20egcw's Avatar
I have GSR's on mine as well, good stuff
Old Jul 4, 2009 | 02:57 PM
ej1love's Avatar
yes, and the ex is the same as the si(5gen)... and the rear sway off the teg would be an upgrade compared to urs if its off the gsr...
Old Jul 4, 2009 | 03:05 PM
ok kool thankz for ur guys help man im gonna upgrade a lot of part to my car
Old Nov 10, 2009 | 10:15 AM
Unseen Racer's Avatar
i know this is an old post but i would like to know the
answer to this question.
are the spindles from a GSR the same as the Ex?
but this is for a 99 civic
Old Nov 10, 2009 | 11:58 AM
thumper64's Avatar
On 5th gens, the 94-95 Civic EX sedan, coupe and I think 93-95 Si used the same front calipers, rotors and pads as an Integra RS. The knuckle is a different part number, but it doesn't matter, the brakes themselves are the same. Unless someone wants to measure them and post pictures, I'm going by what the Raybestos brake parts catalog and Honda website say.
I should mention that the Integra RS is the only non-ABS model, but still has the same size parts as the GSR. It's still 10.3" rotors
Bobby_Budds
Suspension & Brakes
57
Jan 22, 2016 01:24 PM
farfrumugen
Jan 5, 2011 07:30 AM
95_GSR_SEDAN
17
Dec 9, 2009 04:25 PM
slvrlude
Apr 8, 2007 12:56 PM
glox
Dec 21, 2003 09:06 PM
