99 integra LS cluster into my 90 civic dx help
Old Jul 4, 2009 | 12:42 PM
es.roadster's Avatar
Default 99 integra LS cluster into my 90 civic dx help
so far this is my second attempt to make the 99 integra cluster work on my car.
i got around to making the 92-95 civic VSS to fit my d-series tranny ( d16a6 si tranny )
now that i've wired everything up, my speedo doesn't work.
i used this link to help me mount my vss:
http://hondacrx881.tripod.com/gsrclusterswap.html
and this for my 90 civic wiring diagram:
http://www.geocities.com/speed_phrea...ow2cluster.htm
and for the integra diagram, i used this:
" VSS diagram "
snap facing away from you ,
power signal ground
power - radio fuse
signal - orange wire on back of the integra cluster / B10 ecu plug ( obd1 converted by me )
** also tried from signal to the ylw/red "leftover" wire from the civic harness, no luck
ground - the dash frame.
please help me out, im stuck !
Old Jul 4, 2009 | 01:25 PM
Default Re: 99 integra LS cluster into my 90 civic dx help
update,
now when i rev, my speedo would go up to 25mph @ 4,000 rpm.
this is just in neutral, not driving at all.
also used another VSS diagram, one that looked to be used/linked many times.
snap facing away from you:
ground power signal
Old Jul 4, 2009 | 03:29 PM
please help!!
speedo no working ahh
Soliveros15
28
Mar 2, 2014 12:46 PM
InTheLBC20
22
Aug 6, 2010 01:59 AM
c for sea
13
Apr 9, 2004 04:41 PM
All_Motor EF9
Jan 4, 2004 05:29 PM
2fastcivic
13
Sep 7, 2001 09:09 AM
