2008 Honda Civic Si N/A with Mods FlashPro Dyno Tune Results
2008 Honda Civic Si
Mods
- Injen Cold Air Intake with Apexi Air Filter
- Skunk2 Race Header
- Skunk2 70mm Exhaust
- Skunk2 Fuel Rail
- NST Pulleys
- P2R Throttle Body Spacer with Gaskets
- P2R Intake Manifold Gasket
- Ingalls PowerStick
- Ingalls Engine Torque Dampener
- Hondata FlashPro with Custom Tune
I went to Proven Power today and he did a quick $100 Tune with my new FlashPro and this is what I got.
I need some IPS CAMS and a Valvetrain Kit. I want 250HP N/A and I will be happy!
I need to beat last week's 14.651 sec @ 97.21 MPH 1/4 mile run running Hondata's generic MAF map. Hopefully I can beat it with this custom MAP map
Proven Power Custom FlashPro Tune = 216.82 HP / 154.55 TQ
Stock Honda Tune = 198.75 HP / 150.96 TQ
Gain = 18.07 HP / 3.59 TQ
Mods
- Skunk2 Fuel Rail
- NST Pulleys
Maybe you guys can help me?
I photoshoped the lines in for reference from my last dyno. But it seems that the only time that I go over 14 AFR is from 4600 RPM to 5600RPM. Should I be near a constant 13:1 AFR at all times or what on a N/A engine? Or do I risk detonation and engine knock if I leave it as is? I'm a newb when it comes to tuning...
2008 Honda Civic Si
Mods
- Skunk2 Fuel Rail
- NST Pulleys
Mods
- Skunk2 Fuel Rail
- NST Pulleys
looks like cams will help you I am looking for the same thing untile I have the money to go all out between 250 and 300hp. I have ingen CAI, LSD cat back , heatshield I am getting Fpro & tune soon and adding at the same time a buddy club header cams & springs. I cant figure out what springs/ cams to get! whats the diffrence with cams and the diff companies suplying si cams?
Is your VTEC crossover set at 4k RPM? You should really tune out that AFR dip there. Also, I doubt you have drastic enough mods yet to really gain much switching to a MAP tune. Did you do a before and after run?
Because that run was the one that made the lowest power "before", so he used it to compare to make himself look good, even though he clearly didn't rev that one out. The one "stock" run he revved out made 207 peak HP, so you really gained closer to 10 peak HP. Your midrange gains are much better, obviously. Did you have any mods done during those "stock" runs? This guy needs to calibrate his dyno if he's telling people their stock Si is making 207 HP at the wheels. But it's more important that you do your before and after runs on the same dyno, so that's just a small nitpick.
And im pretty sure, he didnt have any mods during the "STOCK" run, when it clearly states stock run, just the flashpro. Which gave him that extra kick in the low to mid.
none. k series cams are interchangeable.
u just need to know what you're getting yourself into before you go through with it.
be ready for down time, and some problems.
i cant wait to get my hands on the hybrid racing k series timing chain tensioner =]
V-SPEC 1
25
Jul 19, 2016 10:05 AM
tapiasradiator05
Honda Civic (2006 - 2015)
Jun 2, 2012 08:57 AM
mobiustech
Engine Management and Tuning
Jul 4, 2009 05:14 PM
