installing manual shifter into auto eg
ok so i know where to drill the holes, but does the rubber mount (with two holes, and dowel pins) does it go on the inside of the car, or underneight?
thanks
thanks
did you look at the auto-to-manual swap threads here? lots of pictures and whatnot to help you further.
loook at the stickies at the top of the 92-00 civic/del sol page, click on teh FAQ's
yes i have looked at the faqs however, they stop at the removal of all the factory equiptment. it does not cover the installation.
for some reason, I thought they had pictursof removing the autotragic and installing the manual stuff. maybe ift was on another site.
either way, there are 2 big circle imprints on the interior side. that is where your 2 bolts will go through, but I thuink what you need to do is install teh motor and tranny, torque down everything on that side of the shifter/stabilizr, then simply hold it up to the underside and drill your holes. use grade 8 or 10 bolts and a lock washer, would suck for it to fall out during driving lol
better yet, get some nylon nuts, but be aware they are very difficult to remove. kinda a one time install. but they will stay in without a lockwasher. if you ever had to remove one, you would need a person to help you out, one under the car with a wrench, one on top with a ratchet or impact
Yeah I know, but I also need to get bushings (Energy Suspension most likely) and some bolts and nuts for it.
I could also use a spring pin, I don't like the side-to-side slip an 8mm threaded bolt gives.
and i did use a lock washer, and a vinyl threaded nut, with locktite.
its never coming off XD
Curlybandit
Transmission & Drivetrain
Mar 5, 2013 07:16 AM
srt4pilot
May 28, 2009 03:02 AM
untuned
Jun 4, 2008 08:13 PM
Dyce
13
Aug 21, 2007 03:49 AM
AnitRiceSuperStar
11
May 1, 2006 08:31 PM
