need help in installing steering wheel
Old Jul 4, 2009 | 04:18 AM
civic-one's Avatar
Default need help in installing steering wheel
Hey all. Does anybody have a link to how to make the horn work after an aftermarket steering wheel is installed. Ive searched but found nothing but info on eg's my car is an EJ6 ( or 98 civic ). Also what is this spacer looking thing together with the hub that has two flaps on the side. Exactly like this on pic #9 on this link http://hondaswap.com/civic-crx-ef/ho...g-wheel-73433/ . Thanks all in advance.
Old Jul 4, 2009 | 05:09 AM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: need help in installing steering wheel
go to honda ask for a shoe horn for the steering wheel i forgot the part number i will edit later.
other wise take off the hub again and place a one of those metal handle off a pentel pen and connect a wire from that handle to no. 6 pin in the yellow connector under the dash. try a search you`ll find it easily
Old Jul 4, 2009 | 05:30 AM
civic-one's Avatar
kool thanks. Ill give Honda a shot. One more question . . . which horn button do I use the one with two connectors or just one?
Old Jul 4, 2009 | 06:05 AM
https://honda-tech.com/forums/honda-acura-28/____-nrg-short-hub-quick-release-nardi-steering-wheel-installation-pics-1887852/ for the installation using the pen
http://community.webshots.com/album/49459198Cjsfnx using the shoe horn.
the shoe horn is just a more OEM and cleaner way of installing the wheel.
Old Jul 4, 2009 | 07:31 AM
civic-one's Avatar
Nice thanks. And which horn do I use. Its because mine came with two one is with 2 connectors on it and the other has one connector. When using the one with the two connectors where will I get the other wire from?
Old Jul 8, 2009 | 02:50 AM
civic-one's Avatar
Nvermind. Figured it out will post pics and all on how to do it.
Old Aug 8, 2009 | 09:40 AM
got any updates?
eg6squad
Jan 23, 2013 11:52 PM
vroomeo
Feb 20, 2010 08:12 PM
r3sgtec
May 28, 2007 07:16 PM
JDM_COUPE94
Mar 6, 2007 07:03 PM
rsxsav69
14
Jun 26, 2005 03:17 PM
