ball bearing to sleeve. will i hate it?
Old Jul 3, 2009 | 10:08 PM
redtegra's Avatar
Default ball bearing to sleeve. will i hate it?
i have a GT2871R and for some reason the bearings got badly damaged and the shaft is crooked so the turbo is 100% scrap and non rebuildable. it only had 2300km on it and im extremely pissed about the whole thing. my turbo guy said he can convert my turbo to a sleeve turbo for about the same price it would of costed me to rebuild it. around 650$ cnd. a new ball bearing turbo is 1400$ cnd. will it make a huge difference spooling wise? what else will i notice?
Old Jul 3, 2009 | 11:41 PM
blinx9900's Avatar
Default Re: ball bearing to sleeve. will i hate it?
Why not go through the Garrett exchange program and get yourself a new CHRA?
Old Jul 4, 2009 | 12:07 AM
Boosted_B_Series's Avatar
I'd do the exchange program or buy a new turbo.. not so sure about your 650 rerigging deal
Old Jul 4, 2009 | 04:47 AM
96 GSR-T's Avatar
You can just buy a new CHRA, I had to do that last year I only had 1500 miles on my BB 67ho when something clogged the restrictor and boom it was cooked.
Old Jul 4, 2009 | 07:34 AM
Joseph Davis's Avatar
A small turbo like G/T28 you really aren't going to get anything from ball bearing. A big turbo, like the previous poster's BB T67, there's a big difference in re-spool up between shifts and that's where BB comes in handy.
Frankly, the exchange program is your ticket. The resale on your turbo, if you need to move it, will be a lot higher for the same outlay of cash.
Old Jul 4, 2009 | 08:48 AM
iliv2xlr8's Avatar
I too would stick with the exchange program. It doesn't make sense to spend $650 for a conversion.
Old Jul 4, 2009 | 01:31 PM
redtegra's Avatar
you guys have to remember im in canada. the prices are a lot higher. not only cause of the exchange rate but just everything in general is higher priced. but thanks ill check into the exchange program.
Old Jul 4, 2009 | 01:38 PM
redtegra's Avatar
when they say "*At a minimum, the center housing must be re-usable to qualify for this program." that means they just need the housing itself gutted? ill give them a call on monday and see what they have to say.
Old Jul 4, 2009 | 09:39 PM
R.A.T.'s Avatar
Hey Jason, wish you best of luck but hurry and fix that turbo... we need to go do some runs together!
Old Jul 4, 2009 | 09:55 PM
TheShodan's Avatar
Moderator
This is referring to the bearing system Center Housing Rotating Assembly (CHRA) aka "center cartridge" must be in good condition in order to be part of the exchange program. This means the warranty is limited to wheel/shaft damage before it will be CONSIDERED for replacement. If the CHRA has failed (i.e. radial or axial play, or saturated oil pressure) it will not be honored
Old Jul 4, 2009 | 10:52 PM
doudlidou's Avatar
I got a gt2871r too for my gsr. I am installing it right now. I live in gatineau, 2hours from mtl, would be nice to see you and makes some runs
Old Jul 5, 2009 | 06:58 AM
96 GSR-T's Avatar
So if I starved the turbo of oil and the bearings exploded and caused the wheels to move inside the CHRA to the point where the wheels were grinding on the Hot/Cold side housings, would this be honored?
Old Jul 5, 2009 | 08:59 AM
TheShodan's Avatar
Moderator
No. Unfortunately, in a situation like that the exchange would not be honored by Garrett.
Old Jul 5, 2009 | 07:51 PM
boost4life's Avatar
if it cost you 650 dollars i would by a t3-61 and never look back
redtegra's Avatar
alright thats what i thought. the turbo was still working just that the bearings got damaged and apparently the shaft was a little crooked so its not rebuildable. sounds like im good for the exchange. going to give garrett a call tomorrow. thanks
Old Jul 5, 2009 | 07:59 PM
redtegra's Avatar
yeah im working on it man.. still got a bit to do though. hopefully in august it'll be running again. i just havn't had any luck whatsoever.
sure i'd be down.
that would cost me around 950$ plus the cost to change the flange for the exhaust. im hoping the garrett exchange will come out cheaper then that.
Pikachu
Mar 14, 2005 09:12 PM
NVturbo
Feb 22, 2005 09:52 PM
redboost10
Oct 28, 2003 10:25 AM
Hard2Find
Jun 2, 2003 02:49 PM
freakie
Jan 9, 2003 10:15 PM
