New Fuel Lab Mini Fuel Pressure Regulators
Old Jul 3, 2009 | 04:13 PM
B R Fittings's Avatar
Default New Fuel Lab Mini Fuel Pressure Regulators
Fuel lab has come out with their new Mini regulators. They are much smaller then a traditional fpr. They only weigh 5.25 oz. as opposed to 12 oz. for their regular sized ones. What I really like about these fpr is the ability to mount them on the fuel rail. With their size and light weight design they don't look awkward mounted on the fuel rail like their regular sized fpr.
They come in two different pressure ranges also. A 25psi-90 psi range and a 90-125psi range. These ranges represent the base pressure adjust ability. So if your running a walbro intank pump in conjunction with bosch 044 inline and ID1000cc injectors. You will need a high base pressure (90+psi base)to get the most out of the fuel setup. So you would use the fpr with the 90-125psi range.
If your running just a walbro intank then the 25-90psi one would fit nicely.
Another plus to mounting it to the fuel rail is you only need one line as opposed to two lines.
Old Jul 3, 2009 | 05:02 PM
da_dude's Avatar
Default Re: New Fuel Lab Mini Fuel Pressure Regulators
Nice...
Old Jul 3, 2009 | 07:15 PM
mrbsponge's Avatar
got any comparo pics next to the average aeromotive?
Old Jul 3, 2009 | 09:12 PM
No we don't, but the dimensions are 2"W x 1.5"D x 2.25"T.
Old Jul 3, 2009 | 09:31 PM
locash's Avatar
Not that I would ever want to mount one of those regulators on my rail, but make sure people know to use a STEEL fitting if they even consider doing this.. The last thing we need are peoples cars catching fire when the vibration from the motor causes the regulator to break off..
Old Jul 3, 2009 | 11:38 PM
blinx9900's Avatar
kawaii!!!!!
Old Jul 4, 2009 | 01:13 AM
jdm inc's Avatar
Looking good!
Old Jul 4, 2009 | 04:48 AM
96 GSR-T's Avatar
very nice, if it comes in purple I might pick this up over the Weldon...... any idea's on the price?
Old Jul 4, 2009 | 06:26 AM
Blown90hatcH's Avatar
Fitting sizes?
Old Jul 4, 2009 | 12:53 PM
Originally Posted by Blown90hatcH
Fitting sizes?
They make them with -10 inlets and -6 inlets. The outlet is a -6. The ones we have in stock are -6 inlets.
Yes please use a steel fitting when attaching the regulator to the fuel rail. Our kits come with a steel fitting.
They do have purple as an option for color.
Old Jul 13, 2009 | 05:22 PM
Here's what the kits look like. We're just waiting on the steel o-ring boss fitting which is not pictured. I should have them in stock on Thursday.
Also if you want to get rid of your stock fuel filter. We have a kit for that to.
Old Jul 13, 2009 | 05:34 PM
jdm inc's Avatar
can you pm me a price? Thank you.
Old Aug 6, 2009 | 07:23 AM
MeanGreenMachine's Avatar
Are these a pretty good selling item? Do you have a kit that contains all the fuel line and fittings to mate up with a specific brand name fuel rail such an aem rail or edelbrock rail, golden eagle etc etc?
Old Aug 6, 2009 | 07:37 AM
96 GSR-T's Avatar
Will the fuel filters also survive when using very high base pressures? What are the elements made of and where can replacements be bought?
Are the Reg's Ethanol Compatible? Filters?
Old Aug 6, 2009 | 08:23 AM
project dc2's Avatar
fuelab
Old Aug 6, 2009 | 12:13 PM
RedR's Avatar
how much for that fuel filter kit?
Old Aug 6, 2009 | 03:29 PM
laosonick's Avatar
how high of a base pressure are dual walbaros good for?
Old Aug 6, 2009 | 03:33 PM
96 GSR-T's Avatar
Depends on how you run them, either way they have built in pressure relief valve that I think opens at 70psi.
Old Aug 6, 2009 | 04:06 PM
We use aeromotive elements in the fuel filters. The 10 micron element is rated up to 300 psi, and the 100 micron stainless steel element is rated up to 200 psi. The 10 micron element is ethanol compatible.
If your running methanol or alcohol then you will need stainless steel elements only. We carry those in a 100 micron and 40 micron element.
Old Aug 6, 2009 | 04:18 PM
Yes we do have a kit that includes everything needed to go from the stock hard line to the fuel rail.
The kit comes with:
10 micron fuel filter with o-ring boss fittings
billet aluminum fuel filter bracket
hard line adapter
3 -6 straight hose ends
1 -6 90 degree hose end
3 ft. of ss hose or black pro lite hose
o-ring boss fitting for fuel rail (such as, GE, BDL, AEM, etc)
Old Aug 6, 2009 | 04:44 PM
bigD's Avatar
The kit comes with:
hard line adapter
can you pm me a price, thanks
Old Aug 6, 2009 | 06:07 PM
92redhatch's Avatar
Me 2 please^
Old Aug 6, 2009 | 06:08 PM
92redhatch's Avatar
And for kit price thanx
Old Aug 6, 2009 | 10:01 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
keep the thread as a new item thread. refer to the Marketplace -forum for pricing. aske tech questions in here please
Old Oct 1, 2009 | 09:57 AM
Evil Ryu's Avatar
pm with price and tech stuff if applicable
