89 Civic Si front rotor
Old Jul 3, 2009 | 11:27 AM
Lim's Avatar
Lim
Default 89 Civic Si front rotor
I just picked up an 89 Civic Si and I went to install new Power Slot front rotors. When I jacked up the car I notice the rotors are different sizes. The Power Slot are 9.5" and the one that's on the car is 10".
Maybe the previous owner swap them?
What will I need to convert them back to Si spec?
Old Jul 3, 2009 | 12:16 PM
Lim's Avatar
Lim
Default Re: 89 Civic Si front rotor
here are some pictures
Old Jul 3, 2009 | 01:30 PM
Clipsed's Avatar
ugh do you mean 10.3 inch? no car that I can recall that is swappable came with 10" rotors, but I could be wrong.
Old Jul 3, 2009 | 06:31 PM
Lim's Avatar
Lim
Yeah it could be 10.3 inch. I didn't get a good measurement with the rotor still on the car.
Old Jul 3, 2009 | 06:36 PM
dephtone's Avatar
It maybe DA front knuckles and rotors. Mine came with 99-00 Si front brakes.
Old Jul 3, 2009 | 07:36 PM
Lim's Avatar
Lim
I could be from a DA...I'm going to swap back the standard knuckles/rotors/calipers.
Old Jul 4, 2009 | 05:47 AM
dephtone's Avatar
If I were you I'd swap the slotted rotors out for the Da ones and be done with it. Everyone could always use a better braking system but thats my .02 Good luck with whatever you decide to do.
Old Jul 4, 2009 | 09:23 AM
Clipsed's Avatar
agreed, bigger rotors=more braking surface. Even if you just had bigger rotors on your stock si calipers, it would still be an upgrade, although it wouldn't be a large improvement over stock, you would have better 60-0 times. You could find out what arms you have by looking at the part number and typing it in to a honda parts catalog.
Old Jul 6, 2009 | 01:54 PM
Lim's Avatar
Lim
From that picture...can anyone tell me what spindle/knuckle is that from?
Old Jul 6, 2009 | 03:37 PM
EL Vap133's Avatar
No not really, they all look similar. Can you see any part numbers on the knuckle?
I would keep the bigger brake set up. What size MC do you have?
Old Jul 6, 2009 | 06:36 PM
90_EX_Civic's Avatar
Mine came with 99-00 Si front brakes which makes it so I can't run anything less than a 15" wheel.
uh, you can put 14's on. as long as it's not the HX. you have to mod the caliper or use a spacer to make the HX fit. but any 14" 4x100 Honda rim should fit 99-00 Si brakes. even the 14x5 90-91 civic EX rims. how do i know, cause it worked for my GSR which run the same 10.3" rotor as your 99-00 si, and are the same as the 90-91 EX brakes.
Old Jul 7, 2009 | 07:25 AM
EL Vap133's Avatar
^^^ Agreed! My 97 Integra had stock 14" rims and it was no problem.
Old Jul 7, 2009 | 08:58 AM
dephtone's Avatar
Ah good info I tried the HX wheels, didn't know about the caliper mod. Thanks for the info!
JDM_EK_JOE
Mar 1, 2006 08:16 PM
04civicsi
Apr 4, 2004 06:22 PM
AmauryR
Jun 19, 2002 06:38 AM
