motor wiring issue
just got a 1990 ef hatch. The previous owner try to do a wire tuke on his own and screwed up all the engine harness, and also mest with the headlight wiring as well. We try to save the engine harness but it was a no go the motor cranks and the injectors dont shoot fuel. We replaced the fuel pump and checked all the fueses and still no fuel. Then we converted it back to dpfi and still no fuel. Can anyone please tell me what they think the problem may be
The fuel pump is priming correct? When you turn the key to start you hear one click the Engine light will come on for 2 secs and then you will hear another click and the engine light goes out correct?
Loosen the screw on the fuel filter to see if you are getting fuel to the filter, if so, replace the screw and remove the fpr hose that comes out of the bottom and see if fuel shoots out there to verify you are getting fuel to the rail.
RacerBoy
Mar 27, 2003 08:05 PM
TheIntegraGuy
18
Nov 22, 2002 05:53 PM
