d15b2 rebuild
Old Jul 2, 2009 | 10:04 AM
sde780's Avatar
Default d15b2 rebuild
I'm trying to get my pistons out, haynes manual says to use a ridge reamer and get rid of the little roughness 1/4 inch down the cylinder wall, is this necessary?
Also, how do I take the main bearing cap off? I've loosened the 8 14mm bolts and it's not budging at all
Old Jul 2, 2009 | 10:16 AM
Clipsed's Avatar
Default Re: d15b2 rebuild
take a rubber mallet to it and give it a few taps to loosen it. Pistons push up and out through the deck where the head gets mounted.
Old Jul 2, 2009 | 10:46 AM
8dxhatchy8's Avatar
x2....main caps are on pretty good, just give em a light tap with a soft mallet, should budge loose...
Old Jul 3, 2009 | 07:12 AM
sde780's Avatar
Sweet got that off, you guys see the dark brown tinge everywhere? It's like a thick coating of oil or something, is it a problem if I don't clean it out? Or will it melt off or something once I drive the engine?
Old Jul 3, 2009 | 09:31 AM
Clipsed's Avatar
I pressure washed all my parts with engine degreaser, you just need to make sure to lube it all back up when putting it back together.
Old Jul 3, 2009 | 11:21 PM
sde780's Avatar
no pressure washer here. i scrubbed for half a day before someone said use gasoline, that worked beautifully
Old Jul 4, 2009 | 01:33 AM
Clipsed's Avatar
Don't use gasoline, I'm no environmentalist, but that **** leaves a mess... Take the parts to your local do it yourself car wash, and pressure wash them there. But don't use gasoline, stupidest **** ever, my friend told me that before, and I told him he's ****ing stupid...
Old Jul 4, 2009 | 05:58 AM
sde780's Avatar
ooh ok. Pressure wash will get it all off? My friends got a pressure washer I could probably borrow, but what's wrong with gasoline? I have a bin that I clean the parts in, have like 2 in thick of gasoline on the bottom, and dip the scrubber in every time I clean it
Old Jul 4, 2009 | 09:20 AM
Clipsed's Avatar
I mean if you have a bin that you do it in then it's no biggie, you have to remember there is also oil in gasoline, and when that gets all over the place, it's a big mess... Once you get the motor back together you will have gasoline oil mixing with everything, because you will have coated all of your parts with it.
eg_6sick
Sep 6, 2016 09:18 AM
Hatch23a
Apr 24, 2013 02:13 PM
89 SI zero
Apr 13, 2013 11:09 PM
lsvtec225
Mar 23, 2007 08:06 PM
b16 matt
Jan 24, 2006 07:50 PM
