Tuning an OBDII w/auto trans
Old Jul 2, 2009 | 09:41 AM
96halx's Avatar
Icon2 Tuning an OBDII w/auto trans
I'm building a stroker engine in my 96 accord (f22b2), and one of the parts I plan on using is a bisimoto level 2 camshaft. Bisimoto says this cam can be run without tuning the ecu, but for the best performance, the ecu needs to be re-tuned. I plan on building the head first, and running it on a stock, rebuilt engine until the stroker is completed. While the cam is on the stock engine, I don't need it tuned in, but when it goes on the stroker block I'd like to tune it in with the rest of the upgrades.
Sorry for the whole back-story there, my question is, what can I do to tune the ecu for the cam (and stroker setup)?
Old Jul 2, 2009 | 04:49 PM
mtber's Avatar
Default Re: Tuning an OBDII w/auto trans
Contact your local honda/acura dyno tuning shops for a solution.
Using a TCM & chipped obd1 ecu maybe the best solution, but it will be expensive & a pain to setup.
Old Jul 2, 2009 | 05:15 PM
96halx's Avatar
expensive and a pain = worst solution . Why would it need to be tuned, more air intake than the ecu can handle or what? If that's the only problem, might just go with level 1 or something.
Old Jul 2, 2009 | 07:23 PM
mtber's Avatar
Once you change the cam, you are changing how the engine runs.
It is literally like taking a different engine & putting it into the car.
The ecu you have now isn't programmed for it, hence you will need to program the ecu to run the new engine setup.
91accordcandy
Oct 24, 2013 09:47 PM
Mishako129
Apr 7, 2013 06:32 PM
bigsnorlax
Jul 7, 2009 10:59 AM
maxx5905
Engine Management and Tuning
Apr 14, 2008 11:38 PM
Ragecloak
Feb 17, 2005 12:04 AM
