thermal paste
Old Jul 1, 2009 | 06:00 PM
downest's Avatar
Default thermal paste
I've heard of this stuff and seen it but I don't know where to get it or what's a good brand. Basically what it is is a paste that absorbs heat so you can weld on and close to something that will melt, like rubber bushings or boots. I make shift linkages with different joints this and the way I do it now is kind of a PITA to set up and takes a while letting it cool down to make sure nothing melts.
This is what they look like, you can see the rubber and the grease inside would easily melt/burn:
Old Jul 1, 2009 | 06:07 PM
CarTunr22's Avatar
Default Re: thermal paste
maybe make a liquid cooled collar?
Old Jul 1, 2009 | 06:23 PM
jlude90's Avatar
We used that in the AC business when i did that, you can try an AC supply house and see what they have for protecting stuff behind what you're soldering on. Since you sometimes have to put the torch angled towards something you don't want to burn.
I want to say it was called "Hot Damn" but i can't remember
Old Jul 1, 2009 | 07:05 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
That is pretty far away to be having problems "melting" that bushing. Also those are smaller welds looks like you are using .020" wire. Skip/stitch weld it and you have no problems. Worst case scenario get some header wrap or some type of other heat shield. Also just because the paste may "absorb"/deflect it don't mean that heat transfer won't be there and melt the inside or the sides of the bushing.
Old Jul 1, 2009 | 07:27 PM
downest's Avatar
I'm not using any filler on there, just fusion... the ridge at the end is part of the stock piece that holds the roll pin. It gets hot enough to boil the water I put it in, don't really want to take chances on a $70 joint like that.
Old Jul 1, 2009 | 10:11 PM
ROTARY's Avatar
http://www.harborfreight.com/cpi/cta...emnumber=97821
I've used this before and it works good, they have this stuff in their stores so you don't have to order it.
Old Jul 1, 2009 | 10:54 PM
downest's Avatar
Awesome, just what I was looking for. I love HF's shipping, it's actually cheaper than me driving up to the nearest store. I got my engine crane from them and shipping was somehow IIRC $12. They didn't have it in stock at my local store but it worked out better to ship it anyway.
Thanks!
Old Jul 3, 2009 | 09:20 PM
ROTARY's Avatar
no problem, everything about HF is wacky.. sometimes they have two of the same item but with different item # and price. i almost shat my self when i saw hylomar sealant on the shelves for under $3 finding the thermal gel was bonus haha.
Old Jul 4, 2009 | 06:00 PM
srmofo's Avatar
holy crap! they have hylomar for 3$!!! I might have to stock up.....think its counterfeit chinese crap? they're starting to do that with alot of products now
Old Jul 4, 2009 | 06:28 PM
CSaddict's Avatar
I use something called Thermaltrap at work.
Old Jul 5, 2009 | 01:26 AM
ROTARY's Avatar
yeah its the real stuff, check out the link. http://www.hylomarblue.com/where_to_buy.htm
Old Jul 5, 2009 | 07:35 PM
90blackcrx's Avatar
http://www.kalyx.com/store/proddetai.../8855/file.htm
Old Jul 6, 2009 | 09:15 AM
Sobe_Death's Avatar
I checked your website but didn't see any more info about that linkage of yours. Any more details?
Old Jul 6, 2009 | 09:42 AM
downest's Avatar
I don't want to turn this into a commercial thread and get it locked, please keep that to PM/email. Basically I replace the worn out factory joints or the notoriously sloppy HASport ones. Most of my customers have CRXs so all the parts are getting up in age.
envision
Dec 20, 2012 01:21 PM
IP RACING
Mar 13, 2009 09:16 AM
CRXperiment
May 7, 2007 05:21 PM
RustyDX
17
Sep 5, 2006 11:49 PM
grtek
May 18, 2006 12:29 PM
