When vtec hits there's a loud click
Old Jul 1, 2009 | 12:48 PM
Danielsb20crx's Avatar
Default When vtec hits there's a loud click
hey whats up i just put another b20 vtec together i ran the car for about 1000 miles without popin vtec i just hooked the vtec wire up today and to see really what my 4 door is pushing the setup runs like a raped gorilla with vtec but right when it hits vtec you hear a loud click and bam!! vtec it seems like its the vtec lockers in the head but it runs flawless or i think that my vtec is to low it comes on at 4500 rpm what do you guys think
Old Jul 1, 2009 | 01:17 PM
blazzer's Avatar
Default Re: When vtec hits there's a loud click
either drop you vtec to 4200 or try raising it to 4800-5200 maybe
curious did you torque the lost motion assembly properly?
does sound like it could be the rockers clicking hard with the oil pressure when the vtec is activated(although a click to me does not sound healthy)
like you stated if you have a vtec controller or chipped ecu try slightly adjusting the vtec rpm activation
hmmm your not throwing any codes at all are you before/during vtec?
Old Jul 1, 2009 | 02:04 PM
id just got done tearing the head down and i just put it back together checked everything with the feeler gauge everthing is in spec the head just came off a jdm b18c that i bought last week from hmotors the motor was a perfect runnin motor when got it could it be the high pressure prodrive oil pump gears forceing it to pop vtec could it be maybe to much oil perssure
Old Jul 1, 2009 | 02:11 PM
no C.E.L lights i raised my vtec point to 4800 still the same click the motor does not lose any power at all id say that vtec is working propperly but i do have a 7.5lbs flywheel too could the motor be spining to quick for vtec to keep up
Old Jul 1, 2009 | 04:40 PM
DCRB's Avatar
lol this is sig. status!!! why don't you post up a video of what's happening then we can help you better. did you use a relay to power your mad vtekz?
Old Jul 1, 2009 | 06:18 PM
sirtef9's Avatar
That's a first in 8 years for me lol
Old Jul 1, 2009 | 06:23 PM
Bunger's Avatar
Do you have an oil pressure gauge? If so, what's the pressure at around VTEC engagement?
Old Jul 2, 2009 | 03:40 AM
blazzer's Avatar
ya so then from what your sayin to me that honestly sounds like a lot of oil pressure making that click then
"it could it be the high pressure prodrive oil pump gears"
a good possability^^
Old Jul 2, 2009 | 04:10 AM
gibsanez's Avatar
Get your car tuned for a smooth powerband instead of playing with it yourself.
Old Jul 2, 2009 | 04:15 AM
gnar kill's Avatar
what intake mainfold do you have on there. If it is the gsr intake it might have something to do with the butterflies for the secondary runners opening up......
Old Jul 2, 2009 | 07:55 AM
~sp33~'s Avatar
EFB055
This made me lose all interest in the threads direction.
Old Jul 2, 2009 | 11:41 AM
i have a skunk 2 and sp33 go somwhere else and thread i was just seeing if anyone had the same problem im a 7 year a.s.c cert tech i know how to tune my car im not stupid
Old Jul 2, 2009 | 11:51 AM
92NoTeC's Avatar
do you mean A.S.E.?
Old Jul 2, 2009 | 03:29 PM
.Manny.'s Avatar
Touching My Member
hhhhmmmm..."A.S.E" Certified techs would have more sense than to think a silly flywheel would mess with VTEC engagement, but you said you're a.s.c certified...my bad.
for one...stop messing with the vtec engagement point yourself and take it to a real tuner. Have it dyno tuned. and just like Bunger suggested, check the oil pressure as well
Old Jul 2, 2009 | 03:34 PM
BiG ChOr!Zo's Avatar
this brings back memories of the old vtec thread yo
Old Jul 2, 2009 | 04:25 PM
beana's Avatar
you forgot the "loud click" and the "bam!!"
Old Jul 2, 2009 | 04:35 PM
here's the "loud click" ss.BiG ChOr!Zo.x3
and here's the "bam"
Old Jul 2, 2009 | 05:00 PM
~sp33~'s Avatar
EFB055
Then i would have thought you'd know how VTEC actuates.
Old Jul 2, 2009 | 05:23 PM
jbrokos307's Avatar
asc lol
Old Jul 2, 2009 | 08:55 PM
crxx's Avatar
SO WHAT WAS THE CONCLUSION?
Old Jul 3, 2009 | 06:13 AM
AJxr's Avatar
did you wire in a relay for the vtec? ie: if you are using turboedit you have to wire in a relay for the 1 wire vtec, not sure with any other programs or stock ecus. but yeah my relay made a really loud click when it would activate vtec and i had it mounted under the dash.
Old Jul 4, 2009 | 10:58 PM
lunalink's Avatar
a.s.c = AUTO SUPPLY COMPANY.. my sis worked for them, she had no clue about vtec, i guess you're in the same boat.
Old Jul 5, 2009 | 12:38 AM
K20egcw's Avatar
You should raise your vtec up to like 5800....
Old Jul 5, 2009 | 12:55 AM
~sp33~'s Avatar
EFB055
Originally Posted by lunalink
the same boat.
The FAIL boat
Old Jul 5, 2009 | 01:37 AM
lunalink's Avatar
Originally Posted by ~sp33~
The FAIL boat
EXACTLY!!
xvracing
May 1, 2004 01:49 PM
civickid03
Mar 25, 2004 11:00 AM
