anyone adjust valves before? b18c1
Old Jul 1, 2009 | 12:19 PM
delbert's Avatar
Default anyone adjust valves before? b18c1
okay so here's the problem i have a valve ticking/tapping problem. i adjusted number 1 & 2 already..but when i got to 3 i couldn't adjust the intake side the adjuster screw would move left and right like the others would but wouldn't open more so i can stick the feeler gauge in. is this what they call sticky valves? or is the valve ****ed? thanks anyone!
Old Jul 1, 2009 | 12:23 PM
delbert's Avatar
Default Re: anyone adjust valves before? b18c1
also when i turn the crank by hand like when the cylinder number 3 is at TDC it gets hard and stuck are the valves dropped on the intake side then cuz the exhuast side was fine anyone?
Old Jul 1, 2009 | 06:15 PM
goota's Avatar
well you dont adjust your valves in that order. its 1-3-4-2. also make sure you remove the spark plugs when you do it, or else it gets harder as you crank more and more.
Old Jul 2, 2009 | 09:27 AM
delbert's Avatar
yes i did do it in that order...i adjusted them all. forget the i couldnt do number 3. cuz i kept on hand cranking it a few times around and it eventually loosen up? maybe sticky valves i don't know...and it was stilll tapping? i used 0.006" on intake and 0.007" on exhuast side...still tapping even worse now!...right when my friend started the car i heard it tapping then told him to turn it off..and also after i adjusted all the valves..and i hand cranked it before i started it. it was making like a gushing air noise...i don't know...just stuck now tired of touching it....
Old Jul 2, 2009 | 09:29 AM
delbert's Avatar
bump..
Frase_civic
11
Jul 10, 2012 06:02 AM
codyb13
16
Apr 28, 2005 12:23 PM
Philip
26
Dec 17, 2003 10:18 AM
jdm169
Jan 24, 2003 05:36 PM
