JDM F22A rod bearings help
Old Jul 1, 2009 | 11:59 AM
04ram's Avatar
New User
Default JDM F22A rod bearings help
i have a 91 accord that had a F22A1 engine that died, bought a JDM F22A engine for it, now it needs new rod bearings but have been unable to find the correct ones for it. the parts stores only show bearings for the usdm F22A engines which are larger than the JDM F22A. anybody have an idea on where i can find the correct bearings, the parts stores have no clues about the JDM engines.
thanks
Old Jul 1, 2009 | 02:11 PM
GhostAccord's Avatar
Default Re: JDM F22A rod bearings help
Go to a Honda dealer to buy your bearings. They should be able to get you the bearings you need.
Are you sure that the JDM engines don't use the same connecting rod journal bearing codes as the USDM ones? I thought that they all used a universal colour code system. The numbers or marks should be stamped on the rod or crank to indicate what colour bearings to use.
Note* this is the spec sheet for an F22B1 - 2 & F20B3. The dealer will have the specs for the F22A
Alex EX
Dec 8, 2006 10:56 PM
1point7db2
Mar 29, 2006 11:16 AM
antballs420
Oct 25, 2005 12:02 PM
B18C5-EH2
Sep 12, 2003 01:14 AM
