'91 Civic won't key or roll start - pls help!
Old Jul 1, 2009 | 09:13 AM
jondun's Avatar
Default '91 Civic won't key or roll start - pls help!
Hey folks! So my '91 Civic won't key or roll start all of a sudden. I took a break from work to run over to blockbuster real quick and my car wouldn't start by key, no turning over or clicking at all. The dashboard lights came on, but that's it. The car started and ran just fine earlier in the day. I was able to roll start it at work and drive to blockbuster just fine, no missing or any indication that there was a an underlying issue. I figured I'd just park on a hill when I got to blockbuster and roll start it to get back to work and then deal with the starting issue when I got off of work.
So I get to blockbuster, shut it off and then went to roll start it to get back to work and it started and ran for about 5 seconds and then just died. So when I try to start it with the key I get nothing, except lights on the dashboard.
I've tried jumping it off of my other car to no avail. I've checked the fuses, but don't see any that are blown. I've tried starting it when it's cooler at night and after it has sat, thinking that it might be a main relay issue, but no dice. I've checked around for loose wires, but don't see anything abnormal to my novice eyes.
Can anyone point me in the right direction on trying to ascertain what's keeping it from even turning over by key or even roll starting all of a sudden? Many thanks in advance on any help! I really can't afford a tow and diagnostic bill without even knowing what's causing the issue and how much it will cost to get fixed.
btw - I've checked the distr. cap, rotor button, plugs and wires as well, but if it were one of these parts, wouldn't it at least try to start? I do have some oil on the plugs and plug wires from bad oil tube seals and will get them replaced ASAP, but unsure of whether this would be the cause. I'm guessing that it would still at least try to turn over by key.
Old Jul 1, 2009 | 09:33 AM
BLOWNEF9's Avatar
Default Re: '91 Civic won't key or roll start - pls help!
Sounds like it might be the ignition switch only powering up the ACC wire and not the actual IGN wire.
Old Jul 1, 2009 | 09:49 AM
jondun's Avatar
Originally Posted by BLOWNEF9
Sounds like it might be the ignition switch not powering only powering up the ACC wire and not the actual IGN wire.
Thanks for the reply! Would the ignition switch prevent it from being roll started as well?
Old Jul 1, 2009 | 09:50 AM
D16SiHatch's Avatar
ignition switch is the first thing i thought of as well. test that shizz
http://mycomputerninja.com/~jon/IgnitionSwitch.html
Old Jul 1, 2009 | 09:51 AM
D16SiHatch's Avatar
yep. check your main engine grounds first actually. you might get lucky
Old Jul 1, 2009 | 10:42 AM
jondun's Avatar
Alright, cool. I'll check it and report back. Thanks again!
Old Jul 1, 2009 | 10:59 AM
jondun's Avatar
Forgot to ask and pls forgive my ignorance, but where do I find the main engine grounds?
Old Jul 1, 2009 | 11:22 AM
BLOWNEF9's Avatar
Check the thermostat housing and valve cover grounds.
The more I think about it, the more I am thinking it probably is ground related. I don't think you would have gotten it push started the first time if it had been a bad ignition switch.
Old Jul 1, 2009 | 11:27 AM
jondun's Avatar
Ok, will do. Many thanks for your continued assistance! It's very much appreciated.
Old Jul 7, 2009 | 11:26 AM
jondun's Avatar
I tested the continuity and the Battery(white) to the Ignition(yellow) failed. Heading over today with the new ignition switch...will post results after replacing it.
Old Jul 8, 2009 | 06:35 AM
mjfubar101's Avatar
To bad I have a 6 month old Ignition Switch I could of sent you cheap.
Old Jul 8, 2009 | 11:47 AM
FOrSfEd's Avatar
This happened to me and it was the ignition switch for sure.
ep3og
Jan 4, 2014 04:14 PM
DC5DC2
Dec 27, 2012 08:00 PM
OldskoojdmDA9
Mar 12, 2010 12:13 PM
NBPcivic07
22
Nov 29, 2004 08:58 AM
TurboedGSR
Sep 18, 2002 05:23 PM
