Suspension Issue HELLLLLLPPPPP!!!
Old Jul 1, 2009 | 08:51 AM
JDMBOY1904's Avatar
Default Suspension Issue HELLLLLLPPPPP!!!
I got some megan coilovers they seemed good the first day no noise no nothing!
Then the next day i go over a bump and i hear noised coming from my back shocks!! it only when i go over a bump curved
any ideas:pray:
Old Jul 1, 2009 | 08:56 AM
mustclime's Avatar
Default Re: Suspension Issue HELLLLLLPPPPP!!!
check your spring purches.....aside from that, do not buy crap from the land of the eggroll.........
Old Jul 1, 2009 | 09:27 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Megan coilovers.... no thanks....
I love Buddy Club N+
Old Jul 1, 2009 | 10:44 AM
hawaiiancb74's Avatar
honestly megans are made by bor chuan in tiawan.. along with bc, some functions, and a few other larger names, they are not that bad but they are in a general catergory. ohh btw your buddy clubs, made in the same factory with some of the same parts as the megans..
Old Jul 2, 2009 | 06:09 AM
mustclime's Avatar
As someone that autoX's and track days their car, they are total crap. Here is why...
1) spring rates....for the ep3 the megans are 440lb ft and 550lb r, for the dc5 they are 550lb ft and 660lbs r......the motion ratios of the suspension are .91 in the front and .59 in the rear. What that means is the front is much more stiffly sprung than the rear, this = lots uf understeer....
2) the damping is a mess, the ***** are not even close to being equel in adjustment. Have you even noticed that koni's are sold in matched pairs? There is a reason for that....all of that crap from china/tiawan looks like total crap when you hang them on a shock dyno.
3) the buddy clubs have spring rates that are ok for racing slicks but anything under that grip level will handle like crap....again, tires set your spring rates, spring rates set you damping .....
99% of the coilover kits out there are tuned for lots of understeer and this is the last thing you want with a fwd car. If you want your car to handle well, you have to go custom spring rates...but most of the people on this forum would the horrified by how a properly set up car drives.....
Old Jul 2, 2009 | 06:41 AM
turboteg2nv's Avatar
Thread has been officially jacked and is now a Megan coilover debate
So how does a properly set up car handle compared to boy racer OP w/ his Megan coilovers slammed to the lowest setting?
Old Jul 2, 2009 | 06:54 AM
pg77's Avatar
New User
While you are debating the coil overs can someone provide insight on my issue with a 94 lude. I previously had a 89 si and it handled excellent. When I got the 94 lude the camber in the back went inward toward the top. None of the parts looked bad and the height looked about right. I installed a camber kit at the bolt locations then had an alignment done. The camber was dialed in to nominal but the toe was just at the edge of being out. The car still has lots of sway to it when turning. Any suggestions would be great.
Old Jul 2, 2009 | 07:09 AM
Buy a bigger rear sway bar.
And next time post in the correct forum
Old Jul 2, 2009 | 07:15 AM
pg77's Avatar
New User
Stock is 17-18 mm. I've seen up to 1.25in. What do you suggest is enough without going overboard?
tianporn
Suspension & Brakes
Sep 2, 2014 02:20 PM
Crono139
Sep 2, 2006 01:42 AM
Cabby89
Dec 28, 2005 11:41 AM
AlexLude
Mar 25, 2004 07:14 AM
Krayon
Sep 15, 2003 01:10 PM
