Clutch Differences between RSX and RSX Type S
Old Jul 1, 2009 | 08:26 AM
The AW Alchemist's Avatar
Default Clutch Differences between RSX and RSX Type S
Are there any differneces in the clutch for a regular RSX and a type S Rsx?
Old Jul 1, 2009 | 09:26 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: Clutch Differences between RSX and RSX Type S
To my knowledge no they all swap around.... ep3, base rsx, and type-S
We put a type-S flywheel and clutch on an ep3 and thats a base RSX pretty much
Old Jul 1, 2009 | 10:04 AM
prejdmlude's Avatar
flywheel is diff. so is the clutch but if doing a clutch job most after market clutch want u to install a type s flywheel because of the friction plate and pressure plate being slightly larger
Old Jul 1, 2009 | 07:35 PM
DaveSi677's Avatar
Agreed!
Old Aug 12, 2009 | 11:15 AM
CStyle's Avatar
New User
I'm new so I can't post my own thread, this is the closest topic with the most recent posts that I can find so I'm hoping someone will reply.. I have an '06 RSX type S and I have to replace the clutch and flywheel. I want to do aftermarket but I need suggestions. I don't want a heavy racing clutch or whatever they're referred to as, I'm 110lbs and don't wanna exert too much energy just to shift, lol. Any suggestions are appreciated. thanks.
Old Aug 12, 2009 | 11:27 AM
josh's ep3's Avatar
Function > Form
Just because you are new doesn't mean you can't search.
Competition, Spec, Exedy, ACT, etc... all good brands. Just get a stage 1 or a street type disc and pressure plate and you should be fine.
Old Aug 12, 2009 | 11:48 AM
DaveSi677's Avatar
Josh, I don't think I could of said it better myself!
Old Aug 12, 2009 | 05:53 PM
hawaiiancb74's Avatar
ehh he did fine , he found something close and went with it.. but yeah ide recomend a comp stage 1. check on clubrsx for flywheel and clutch combos
Old Aug 15, 2009 | 03:46 AM
vladd's Avatar
why do you have to replace the clutch and flywheel? any engine mods? if the motor is close to stock then i'd go with an oem replacement, there's no point of getting a stronger clutch unless the oem clutch can't handle your motor's power.
Old Aug 15, 2009 | 07:49 AM
manuelcantarero's Avatar
Even if he has a bone stock engine maybe he should get a stage 1 for the fact that maybe he will or is going to get mods...then he might have to change the clutch again to go with the power
The sweed
Jan 5, 2007 09:01 AM
3vilMonkey!
Oct 21, 2005 08:37 PM
JUN JDM
Jun 5, 2003 09:54 AM
2002desertsilver-rsx
Sep 18, 2002 07:16 AM
