foglights
Old Jul 1, 2009 | 12:54 AM
quirarte626's Avatar
Default foglights
alright so i bought these foglights the other day from this guy
and he said they fit ef8s and hatchbacks..
but i was wondering..what kind of foglights are these? are they a direct bolt to a honda civic hatchback 91 si????
thank you
Old Jul 1, 2009 | 02:52 AM
+honda_monkey+'s Avatar
Default Re: foglights
did he give you the fog light switch too?
Old Jul 1, 2009 | 09:40 AM
Ldo's Avatar
Ldo
88-89 Prelude fogs.
Not a direct bolt-on. You need to fabricate some brackets to mount them.
Old Jul 1, 2009 | 09:44 AM
Radim's Avatar
Did you buy those off Stuna Aaron?
Old Jul 1, 2009 | 09:54 AM
reptile's Avatar
those are prelude fog lights, their nice!!
Old Jul 1, 2009 | 11:19 AM
ALLxMOTOR EG's Avatar
Vietnamese!
Prelude fog lights.
Old Jul 1, 2009 | 11:54 AM
naw he didn't just the fogs
Originally Posted by Ldo
88-89 Prelude fogs.
the brackets that are on it or i need to buy some somewhere?
naw i didn't....
Old Jul 1, 2009 | 12:36 PM
4gen5thtime's Avatar
No you can't really buy them. You have to make your own to do it. Just make it look clean.
Old Jul 1, 2009 | 01:26 PM
oh alright..
hopefully it comes out good..
thanks for all the info
Old Jul 1, 2009 | 01:47 PM
crx_si-r's Avatar
It's an easy install. If you have a usdm front end. You don't need any brackets. When I had them on my Crx all I did was drill hole into the bumper support
Old Jul 1, 2009 | 02:16 PM
Radim's Avatar
It's different for hatchbacks Broski.
Old Jul 1, 2009 | 02:31 PM
phatboi's Avatar
ef8/9 brackets are vertical and you need to cut your stock bumper to make them fit, but there is a outline on the inside of the bumper
Old Jul 1, 2009 | 02:36 PM
Radim's Avatar
are they flush mounted or are they supposed to stick out?
I made brackets for mine already but they stick out about half an inch.
Old Jul 1, 2009 | 08:54 PM
crx_si-r's Avatar
all you gotta do is find a nice position for them and drill a hole. just remove the top tab that comes off on the top of the fog light. i know the supports are different but the process should be the same. no need to cut any part of the support UNLESS you are going to be using a jdm fog light bracket. here is where i drilled a hole for the fog ligths....i made the hole elongated to allow for back and forth adjustment.
Charlie Moua
Oct 24, 2009 04:52 AM
firaga21
Nov 5, 2008 01:37 AM
IAluder95
Honda S2000
Feb 16, 2005 08:19 AM
stevescivic
Jan 29, 2005 08:38 PM
91EXRMANUAL
Oct 30, 2004 12:17 PM
