B20V-tec compression ratio
Old Jun 30, 2009 | 07:14 PM
DA-Flyby's Avatar
Default B20V-tec compression ratio
I just bought a stock b20b block, i have a 95 GSR head. I know about that website that gives you an estimate on what compression ratio could be expected. But according to the site supposively Im gonna be at 9-2-4 ? Is that right? I just want to know the compression
http://www.c-speedracing.com/howto/c...c/compcalc.php
STOCK B20 PISTIONS
STOCK BLOCK(STOCK SHORT BLOCK)
95 GSR HEAD
Old Jun 30, 2009 | 09:06 PM
DA-Flyby's Avatar
Default Re: B20V-tec compression ratio
NEED help here guys, Im about to send the head to get milled.
Old Jun 30, 2009 | 09:17 PM
thabao's Avatar
Dont mill anything. What B20 did buy? JDM B20b? USDM B20b4 or B20z4? Also, are you planning on boosting it?
If it's the B20b4, your compression is correct. That is a good compression for boost.
If your going all motor, i would get some PHK pistons from the B20z4. That'll pump your compression to 10.1:1
Or save up a $180 bucks and get the RS machine 84mm itr copies and that'll get you to 11.6:1
B20b4 are slow, slower than LS, even with a vtec head it'll be slow for an all motor.
Old Jun 30, 2009 | 09:25 PM
DA-Flyby's Avatar
its a JDM B20B
Im going ALL-MOTOR
RS MACHINE 84MM ITR copies, where can i get these??? $180? thats sounds great
I just can't spend 1000 on forged pistons and rods
Old Jul 1, 2009 | 06:19 AM
thabao's Avatar
Well since you have a jdm b20. 3 ways to see if it's the high compression one or not is:
1. look on the back, is there a knock sensor?
2. take off the head and see what pistons are in it. If they are PHK, its the high comp. If it's P3F, it's the low comp.
3. The year, what year is the motor.
Old Jul 1, 2009 | 10:43 AM
DA-Flyby's Avatar
they're P3Fwith no knock sensor. I want nothin less then 10-2-1. but that 11-6-1 with the itr copies sounds even better. What do you suggest?
Old Jul 1, 2009 | 10:51 AM
thabao's Avatar
Sorry for the confusion. The $180 for the RS is actually for the 81.5mm version. The 84mm ones run $310 shipped on ebay.
Now, if thats a lot for you, get the PHK. that'll get you to 10.1:1 still good for boost.
I would get the PHK, use a 2layer headgasket, and port and polish the head with a good intake manifold.
Old Jul 1, 2009 | 11:06 AM
DA-Flyby's Avatar
Im gonna go with the RS pistons(higher compression), should I run the 84mm or 81.5? im guessin the measurements are the length of pistons?
Old Jul 1, 2009 | 11:30 AM
thabao's Avatar
You should run 84mm, it's the width. The bore on a B20 is 84mm. You might wanna get a tune as well and run 93 pump gas only.
Old Jul 1, 2009 | 11:37 AM
DA-Flyby's Avatar
alright, so 84mm RS pistons im looking at 11-6-1 CR, is that on a 2-layer or 3 layer head gasket?
Old Jul 1, 2009 | 11:49 AM
gshatch's Avatar
you probally want to bore out the block to get rid of any damage
just do it right the first time
Old Jul 1, 2009 | 02:12 PM
thabao's Avatar
3layer
Old Mar 13, 2010 | 06:23 PM
EG6Boy702's Avatar
wont a bigger head gasket lower the compression?
Old Mar 14, 2010 | 11:51 AM
skipper28-DC's Avatar
Is this true for all B20vtec N/A? I want to build a setup just like the one discussed.
EFort
Engine Machining & Assembly
Mar 4, 2018 02:24 PM
thabao
Jan 20, 2009 04:01 PM
The Destroyer
Oct 6, 2004 07:51 PM
othick
Apr 2, 2003 04:32 PM
BoM
Aug 11, 2001 07:06 AM
