gsr help??
Old Jun 30, 2009 | 06:34 PM
lilo_goki's Avatar
Default gsr help??
i have a 95 gsr with blox stage 1 cams, skunk2 pro series intake manifold, and was just wondering if i needed to get a adjustable fuel pressure regulator, 310cc injectors, and new fuel pump, i'm about to get a smsp header and 2.5" apexi dunk exhaust system with either a vibrant muffler or a rsx type s muffler. let me know if i need to spend the money on the fuel pressure regulator and injectors.
Old Jun 30, 2009 | 06:50 PM
all-mtr-teg's Avatar
Default Re: gsr help??
Skip the fuel pump, unless your current one is going bad on you. Your tuner will probably tell you to upgrade your injectors though. If you're gonna tune with those injectors, the FPR isn't necessary.
Old Jun 30, 2009 | 07:05 PM
lilo_goki's Avatar
kewl, so i should just get the rc310 injectors then and forget about the FPR. after i install my cams, sometimes my car would have a hard start up, seems like it needs more fuel.
Old Jul 1, 2009 | 06:48 AM
Did you do a valve adjustment after the cam install? Not doing a proper valve adjustment seems to be the culprit most of the times for not starting or hard starting.
Old Jul 1, 2009 | 07:15 AM
00Red_SiR's Avatar
All Motor Mentor
Timing, cam and/or ignition can cause the car to be hard to start as well.
Old Jul 1, 2009 | 08:42 AM
Tell me about it. My buddy calls me up one, day, says he can't get his car to run right after he installed some Blox A cams. I go over and his distributor is retarded all the way to the farthest point.
Old Jul 1, 2009 | 01:52 PM
lilo_goki's Avatar
timing is correct, 16btdc, and i did valve adjustment as well.
Old Jul 2, 2009 | 02:11 PM
lilo_goki's Avatar
also another question, should i get 2.5" exhaust system along with 2.5" carsound cat and 2.5" header or should i just stay with 2.25" exhaust, cat, and header.
2000d16y7
Jul 16, 2007 01:49 PM
ice11honda
Jun 19, 2005 06:55 PM
kaoss_11
Oct 22, 2004 09:43 AM
ATS*Mark
Aug 7, 2004 10:12 AM
buda18
Nov 10, 2003 06:46 PM
