do i need an fpr....i'm confused
Old Aug 21, 2002 | 07:37 PM
_Endless_'s Avatar
Default do i need an fpr....i'm confused
i already got a vortech rising rate fmu and a 255lph in-tank fuel pump to take care of fuel needs. do i still need to have a fuel pressure regulator or the stock fpr will do? if yes, why do i need one?
Old Aug 22, 2002 | 09:30 PM
i2un's Avatar
Default Re: do i need an fpr....i'm confused (_Endless_)
I believe that most people who have the upgraded fuel pump, rising rate fmu and a aftermarket fpr...run that combo with larger injectors. I believe the point of the fpr is to lower the fuel pressures lower than stock levels to help the bigger injectors idle better. I don't have any specifics on your set-up but if your running stock injectors you should'nt need an aftermarket fpr unless your trying to do some engine dress up stuff.
Old Aug 22, 2002 | 10:06 PM
rjardy's Avatar
kinda OT but that intank pump isnt going to bee enugh for the FMU, you need an inline, and no you dont need a regulator, stock unit is allright
Rob
Old Aug 23, 2002 | 05:04 AM
RGAZ's Avatar
New User
The stock fpr is ok, if it can bypass enough fuel for the 255. Some setups cannot bypass enough and require the B&M command flo.
What is your idle fuel pressure with and without vacuum?
Randy
gtowni3
Mar 17, 2004 07:59 PM
pelotudo
Sep 14, 2002 12:35 PM
KLN
Jun 3, 2002 11:02 AM
itr501
May 7, 2002 11:04 PM
97GSRT
Mar 28, 2002 04:21 AM
