MOMO horn wiring and getting rid of SRS
I've searched and tried too find out how to wire up the horn and how to get rid of the SRS light
I've heard you can use an EF style shoe horn thing to ground the horn but need to know what wire in the harnes from the reel to tap into.
Also I heard you can use a resistor to turn the SRS light off?
i found both your write ups, but in regards to the horn, I can not locate that black plug that I'm supposed to tap into on my 93 Accord SE. I looked everywhere under the dash and near the column !
Ah you don't mention the year in your post. I assumed it was a CD.
It should be in a similar location. The easiest way to find it is to connect the wires to ground - if the horn goes off you're good. The more scientific approach is look in the Audio/Security forum and find the alarm install guide for your year Accord. It should have the horn wire color listed.
cool, thanks. yeah I can't find any plug that looked like the one you mentioned
I'll look in the the audio/security thread.
Uneekpinoysk8er
Jan 8, 2006 08:13 PM
