Classic Hondas All Pre-1988 Hondas.
Distributor recurving 1.5L
Old Jun 30, 2009 | 04:48 PM
mountainrich's Avatar
Default Distributor recurving 1.5L
Trying to find aftermarket parts like springs and an adjustable vacuum advance for a '83 Civic. Anyone done a complete recurve?
Old Jul 1, 2009 | 04:42 PM
cbstd's Avatar
Default Re: Distributor recurving 1.5L
Yes, I have. It is a VERY worthwhile modification.
There is no "kit," you will have to scrounge the parts yourself. Go to a really good hardware store and ask for help with finding tiny springs. They will direct you to a chest full of drawers full of all sorts of hardware bits and pieces. There will be at least one drawer devoted to springs.
You will want a very small spring. It is probably best if you remove the two springs in the bottom of your distributor to give you a relative size. Do not worry that the replacement springs are not "heavy duty," I have been using the hardware store springs in my D15A3 for years without any troubles.
Re-assemeble the distributor with the new springs and you are good to go. The vacuum advance is not much of a factor in the ignition, the lighter springs are the most important factor in incresing advance more quickly and yielding better performance.
Scott
Old Jul 10, 2009 | 08:19 AM
thegave's Avatar
Is this for the 2gen models?
Is there a slightly more comprehensive, idiot-proof guide somewhere?
Old Jul 10, 2009 | 04:53 PM
cbstd's Avatar
How tough is it? You dig out the old springs and put in new ones.
Old Jul 10, 2009 | 11:34 PM
thegave's Avatar
So that's it. Replace the springs in the distributor with... Lighter ones. Meaning less stiff?
Old Jul 11, 2009 | 12:33 PM
Got any idea of what RPM full mechanical advance should be at? Note:mild engine-bit better than stock.
Old Jul 11, 2009 | 03:17 PM
cbstd's Avatar
Yes
Old Jul 11, 2009 | 03:20 PM
cbstd's Avatar
Back in the old days you could put a distributor on a machine made by "Sun" and it would tell you exactly what the advance curve would look like. I don't have access to one of those antiques and so I can not tell you exact numbers.
But everyone who has made this modification has been pleased with the results.
Scott
Old Jul 11, 2009 | 04:34 PM
I did the recurve a couple of days ago. Response is better-but w/the crap carb I went conservative and used what I would call MEDIUM springs. (Looser than stock-but by NO means LIGHT) Are LIGHT springs the best period, or should 1 LIGHT and 1 MEDIUM be used? I'm familiar w/ HEI spring kits and what they use for light,medium, etc. Can you compare w/ these springs?
Old Jul 14, 2009 | 05:15 PM
thegave's Avatar
Mountainrich, would you mind taking pictures and measurements of the springs so I know what to look for?
I assume the distributor won't work without the springs and I need to drive to the hardware store..
cheers
Old Jul 15, 2009 | 10:27 AM
cbstd's Avatar
It would work without the springs... poorly.
I always suggest that you source a junkyard distributor for this modification, this reduces the "I gotta get it runnin' again" pressure.
Scott
Old Jul 28, 2009 | 11:56 AM
thegave's Avatar
I've not really had too much luck finding a scrappy one so far.
Just out of curiosity, aren't there any dizzys from other engines with more aggressive ignition curves that could just be dropped in to the 1500?
Old Jul 28, 2009 | 06:24 PM
cbstd's Avatar
No
Old Aug 23, 2009 | 03:05 PM
anyone interested in a recurved distributor for an 80-83 civic? These are easy to recurve but the availability is scarce.
David @ Synchrotech
Dec 23, 2016 10:19 AM
Paluce
Suspension & Brakes
Dec 8, 2008 08:59 AM
cbstd
Jan 13, 2005 11:03 AM
