Distributor recurving 1.5L
Re: Distributor recurving 1.5L
There is no "kit," you will have to scrounge the parts yourself. Go to a really good hardware store and ask for help with finding tiny springs. They will direct you to a chest full of drawers full of all sorts of hardware bits and pieces. There will be at least one drawer devoted to springs.
You will want a very small spring. It is probably best if you remove the two springs in the bottom of your distributor to give you a relative size. Do not worry that the replacement springs are not "heavy duty," I have been using the hardware store springs in my D15A3 for years without any troubles.
Re-assemeble the distributor with the new springs and you are good to go. The vacuum advance is not much of a factor in the ignition, the lighter springs are the most important factor in incresing advance more quickly and yielding better performance.
Scott
But everyone who has made this modification has been pleased with the results.
Scott
I did the recurve a couple of days ago. Response is better-but w/the crap carb I went conservative and used what I would call MEDIUM springs. (Looser than stock-but by NO means LIGHT) Are LIGHT springs the best period, or should 1 LIGHT and 1 MEDIUM be used? I'm familiar w/ HEI spring kits and what they use for light,medium, etc. Can you compare w/ these springs?
Mountainrich, would you mind taking pictures and measurements of the springs so I know what to look for?
I assume the distributor won't work without the springs and I need to drive to the hardware store..
cheers
cheers
I always suggest that you source a junkyard distributor for this modification, this reduces the "I gotta get it runnin' again" pressure.
Scott
I've not really had too much luck finding a scrappy one so far.
Just out of curiosity, aren't there any dizzys from other engines with more aggressive ignition curves that could just be dropped in to the 1500?
David @ Synchrotech
12-23-2016 10:19 AM
cbstd
01-13-2005 11:03 AM
