JDM Headlight install
Old Aug 21, 2002 | 07:15 PM
The Punisher's Avatar
Default JDM Headlight install
I remember there being an article on Hondaprelude.com about wiring up a relay so the H4 bulb could be used as high and low beam. Does anyone have this article or know where I can get it from?
Old Aug 21, 2002 | 07:37 PM
satan_srv's Avatar
Default Re: JDM Headlight install (gsr*lude)
What do you need to know..I have done it on my car.....buy a 5 pin relay and it should become fairly evident.
High Beam to the "switching Mechanism"
Low beam to the power in
Ground to the Low beam ground on the relay
87 and 87a to the Low and high beams
lastly the high beam lead to the ground on the light.
I can make you a picture tomorrow while I'm killing time at work. do you want the H1 fogs to work?
[Modified by satan_srv, 11:38 PM 8/21/2002]
Old Aug 21, 2002 | 08:07 PM
PrecisionH23a's Avatar
Default Re: JDM Headlight install (satan_srv)
i just cut the stock harness and soldered the new ones in. what's the benifit of the high beam low beam deal?
Old Aug 22, 2002 | 04:19 AM
satan_srv's Avatar
Default Re: JDM Headlight install (GudeH23a)
Well there are two filaments in the H4 bulb and personally I don't like the middle lights..
But the advantage is that you can wire the hi/lo's in the outside bulb, and wire the inside ones for fog lights if you want
Old Aug 22, 2002 | 08:35 AM
Yes, high/low in one beam and foglights in the center. Thanks for the responses! I am looking forward to that picture. I am sure once I get the relay it will be clear.
Old Aug 22, 2002 | 08:39 AM
post up the wiring when you get a chance , thanks
satan_srv's Avatar
I will try to construct it from memory...you want the foglight with switch as well then?
Old Aug 22, 2002 | 10:05 AM
ViZ's Avatar
ViZ
i would like to see what you have for the fog light setup, im about to wire mine right pretty soon.. does piaa make a amber/yellow fog light bulb for the inner portion?
James_Starks
21
Oct 16, 2022 12:23 PM
mrbassman001
Jan 7, 2011 10:22 AM
madjdmyo217
Lighting
Mar 29, 2010 04:41 PM
ef yu
Lighting
Mar 15, 2010 09:20 PM
predledude
Oct 27, 2006 08:19 AM
