b17 with itr cams require tune?
Old Jun 30, 2009 | 01:14 PM
chb93's Avatar
Default b17 with itr cams require tune?
hey guys. I have a basically stock b17 i/h/e and I was looking to get more power out of it without going too crazy. After looking around I found out that the b17 has the least aggressive cams out of the b series. I was looking into itr cams because I wouldnt have to get dual valve springs and retainers. If I did get itr cams would I need to get a tune. I know a tune is always a good idea but im kind of low on cash and dont have any kinda of ecu management. Just looking for some input thanks
Old Jun 30, 2009 | 01:52 PM
b19coupe's Avatar
Post Re: b17 with itr cams require tune?
You know that a stock ITR runs dual valve springs on both the intake and exhaust valves, correct?
FYI: You will see more gains overall from tuning stock GSR cams (engine management and cam gear tuning) than you would from dropping ITR cams in untuned.
Old Jun 30, 2009 | 02:43 PM
chb93's Avatar
Default Re: b17 with itr cams require tune?
Thanks for the info. When you say stock gsr cams are you reffering to the b17 cams I already have or cams from a 94 and up gsr
Old Jun 30, 2009 | 03:36 PM
092eg6's Avatar
he meant your b17 cams
Old Jun 30, 2009 | 06:25 PM
numberone's Avatar
this guy know his sh*t!!
Old Jul 1, 2009 | 11:02 AM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
i ran itr cams in my b16 for a long time and nothing ever happen stock valve springs... just my experience good luck
Old Jul 1, 2009 | 11:13 AM
ruffrhyder's Avatar
What is a long time? How many miles, how often did you redline, what was redline set at?
Old Jul 1, 2009 | 12:52 PM
chb93's Avatar
thanks for all the info
Old Jul 1, 2009 | 02:37 PM
ilovemyH0nda's Avatar
a b16 with itr cams what kinda gains can u see from that with itr springs and retainers of course with a tune and any other benefits ie will the redline be higher or what?
Old Jul 2, 2009 | 08:28 AM
hmoobhero's Avatar
always get a tune when putting performance parts on. dont matter if just i/h/e. you're changing the powerband, but thats in a perferct world. the world i live in(like most of us) dont have the money to spend on tuning every single time we upgrade something. thats why you make sure you get all the stuff you want and then tune.
anyways, i've been driving my jdm gsr w/ itr cams w/out a tune for a year and half now with no problems. also, i've been to the track 4 to 5 times but i'm not stupid like other people thinking they can rev to 9k rpm with a chipped ecu. i shift at the stock gsr redline(8200rpm). i could prob go alil longer but i'm not risking my motor for a couple hundred rpm.
crazyimport
Jun 30, 2007 12:43 PM
DA-9mordef
Apr 27, 2006 10:04 AM
GSRintegra_Bob
Oct 10, 2005 09:49 AM
X2BOARD
Sep 16, 2004 11:06 AM
