What ecu should i run? and other technical ?'s
quick intro: my car (96 accord w/ stock f22b2) and my future mods you can see in my sig, But before i put my cam and all the fancy stuff in, as for now im just installing the milled and cleaned up P&P head to put onto my car. So basically it will be a stock f22b2 with just a head milled 30 thousandths installed. Im puttting my parts and doing mods one at a time as i would think it would be kind of neat to see how each one provides and feels to the butt dyno
But My questions is with JUST the milled head being installed do i have to run a 90-93 ecu? And also can i run my f22b2 stock cam in that head? or should i pick up a cheap f22A series cam? reason im asking is that iv heard u want the head to match the ecu.. Now i have the obd2 to obd1 conversion harness to run the necesary ecu (and my P06 to tune once everything is on) but im okay with spending a little more on another stock cam or ecu so i can run it with just the raised CR to see how that does.
Thanks again for any info
. But My questions is with JUST the milled head being installed do i have to run a 90-93 ecu? And also can i run my f22b2 stock cam in that head? or should i pick up a cheap f22A series cam? reason im asking is that iv heard u want the head to match the ecu.. Now i have the obd2 to obd1 conversion harness to run the necesary ecu (and my P06 to tune once everything is on) but im okay with spending a little more on another stock cam or ecu so i can run it with just the raised CR to see how that does.
You have too many things going on here.
First u can use a civic ECU and chip it. That will allow you to use any copy of any ecu you want.
Second If you shave a head it is necessary to get an adjustable timing gear.
Chipped P28 and have it tuned. You're in Richmond - I believe the man's name is Matt Shue (Shue Tuning) I know several people that have gone to him.
Uber i do have the adjustable gear as u can see in my parts list in my signature, and muffin man I am receiving a P06, couldnt i just use that? i beleive that is non vtec as well.. And as far as tuning, could i hobble my untuned car over to him? and hows his work?
down_the_hatch
23
Mar 25, 2010 09:43 AM
dwarfsinhondas
Engine Management and Tuning
Apr 7, 2008 11:47 PM
