Dell Sols with defferent chassis?
Old Jun 30, 2009 | 10:02 AM
da_coolest's Avatar
Default Dell Sols with defferent chassis?
How many Del Sol versions are there? and which is the best one for engine swap like K20?
( I heard that there are several chassis models in del sols. )
Old Jul 1, 2009 | 07:18 AM
da_coolest's Avatar
Default Re: Dell Sols with defferent chassis?
anyone?
Old Jul 1, 2009 | 07:21 AM
shoklid's Avatar
use the search bar to see if anyone else had a thread like this idnt think many ppl know
Old Jul 1, 2009 | 10:19 AM
da_coolest's Avatar
thanks shoklid
Old Jul 1, 2009 | 12:33 PM
Poppins324's Avatar
they are all the same. there is the "S" which came with a 1.5 single non. and then there was the "si" which had the 1.6 single with tec. and then the "vtec" which came with the b16 but otherwise they were all the same. The K will go in any of them. but atleast try and get a SI cause it will have 4 wheels disc brakes.
Old Jul 1, 2009 | 02:23 PM
roadsqueegy95's Avatar
ya id get a si, just cuz is has all the options of the sol vtec, just minus the b16 i believe. and it would be cheaper and easier model to find!
Old Jul 1, 2009 | 02:44 PM
shailoche's Avatar
X2 on the Del Sol model history.
When in doubt check Wikipedia....
http://en.wikipedia.org/wiki/Honda_Del_Sol
There were 3 Del Sol's made...
S
Si
VTEC
Those differences were engine only...with the exception of the 1993 S model having drum rear brakes instead of 4 wheel disc brakes.
The only other physical difference in the models was the deletion of the auxiliary lights being removed for the 1996-1997 model year.
Old Jul 1, 2009 | 03:19 PM
metal41mulisha's Avatar
theres actually quite a few differences from year to year. many were all pretty minor though so will you notice a difference? no. but try for the si or just buy the s and do a disc conversion. motor wont matter if your k swapping so dont waste the money on the vtec
mikeycivics
Oct 3, 2011 10:23 AM
krazbiker118
Jan 8, 2009 09:30 AM
itsmejto
Jun 13, 2008 02:10 PM
89civicb16a1
May 20, 2006 09:50 PM
