Installing Race Harness
Old Aug 21, 2002 | 06:48 PM
ransack's Avatar
Default Installing Race Harness
I'm gonna install racing harness in my 96 hatch, does anyone know any site that have instructions on how to. Im looking to do it without drilling holes, but I will if I have too. thanks
-Jesse
Old Aug 21, 2002 | 06:54 PM
Trooper's Avatar
Default Re: Installing Race Harness (ransack)
You could cheat like me. I have the Sparco 3 point harnesse. The boutum 2 are ltached togather . ( my kit cam with bolts that have a hook on top) So i used one bopt and latched the two togather. and for the back i boulet it to the seat belt hole.
Old Aug 21, 2002 | 07:51 PM
VTEC
Guest
Posts: n/a
You can try scca.org and other sanctioning bodies. Be careful, if you mount harnesses incorrectly, such as on an Arospeed floor bar, you risk serious injury if you are involved in an accident.
Mounted properly, harnesses (I hope yours are certified) can help save your life. If mounted wrong, they will harm you more than help you.
Old Aug 21, 2002 | 07:58 PM
tonyxcom's Avatar
you really shouldnt use race harnesses without a roll bar. I am dead serious on this one too.
Old Aug 21, 2002 | 08:08 PM
JV's Avatar
JV
Who?
Default Re: Installing Race Harness (tonyxcom)
Please explain...
[Modified by JV, 12:09 AM 8/22/2002]
Old Aug 21, 2002 | 08:11 PM
smokin rubber's Avatar
Default Re: Installing Race Harness (JV)
you strapped into a car, car get in accident and rolls, your head = roll bar.
DelSol808's Avatar
Please explain...
if you roll your car you cant move out of the way because the harness holds you in so if your roof comes in ontop of you theres nothing to stop it and since you cant move the first thing it hits is your head... a roll bar will keep it above your head and prevent it from caving in on you.
Old Aug 21, 2002 | 08:41 PM
tonyxcom's Avatar
Default Re: Installing Race Harness (DelSol808)
with regular car seatbelts, you can move sidways in your seat if the roof were to get crushed in. With harnesses, you cant move ANY way. And like the person said, you become the roll bar.
This has been covered a lot in the rr/ax forum and there is some really good info there.
-ransack, I told you about this concern when you brought it up at the autox last week. They are fine to use DURING the autox, because civic seats have NO lateral support. But I would NEVER use harnesses on the street without a rollbar. And I even have a rollbar and still choose not to use harnesses.
But it is your car and your life, just consider what I have said, and do a search in the roadracing forum for more proof, then make your own educated decision.
[Modified by tonyxcom, 5:41 AM 8/22/2002]
Old Aug 21, 2002 | 08:58 PM
JV's Avatar
JV
Who?
I don't have harnesses, probably never will... I just wanted to know the reasoning behind it.
Thanks guys...
Old Aug 21, 2002 | 09:49 PM
ransack's Avatar
Yeah, I know that you told me about that. I was going to do it only during Auto-X, cause I feel better strapped down to that seat. Then on the street use the regular seat belt. I totally understand the flipping part. That would suck majorly. But now that I look at it, I could have a more likely chance rolling on the track too. Sorry Tony if you didnt think I took your advice seriously, I did, just being me, thought 'hey why not just use it during auto-x'
but in any case, how much are roll bars. I've always like to be strapped down when at high speeds or racing, ride, whatever. I've used a harness on a dune buggy before, and it for more comfortable not moving.
Thanks for help guys
-Jesse
Old Aug 21, 2002 | 10:16 PM
joeseph's Avatar
Old Aug 21, 2002 | 10:21 PM
tonyxcom's Avatar
Ransack: I am sure you can get a autopower or similar bolt in type bar for 400 or less. Never priced one out.
Or maybe look into some more supportive seats. You can get 94 up integra seats for 250 or less for a front pair. Much more supportive then the stock civic seats.
Old Aug 21, 2002 | 10:28 PM
ransack's Avatar
Thanks Tony
I feel way more comfortable racing like that more supported in my seat. I'll look into that w/ that sway bar and KYBs
Old Aug 22, 2002 | 04:03 AM
CivicSiRacer's Avatar
Also the shoulder belts should not be less more than 45 degrees. Another words go past the seat to the floor. In an accident the harness will compress your spine and can cause paralysis or death.
Old Aug 22, 2002 | 08:16 AM
owen_the_soyboy's Avatar
Rollbars/Harnesses? --->check my homepage for a few pics of my Schrothe Rallye 3 harness, it is a 3 pt harness that's more like a 4 pt with one single rear common mounting point in the back. I also have a "race rollbar" from Autopower in that civic. It was about $450 shipped including the optional harness guide bar. The rollbar made the car a lot stiffer, took about 30 minutes to install and weighs maybe 60 lbs. Also I cannot use the rear seats for passengers with this setup, and the install took a short time because I have no rear interior to cut thru. I took another leap and went for racing seats to help save the weight I gained using a rollbar, and I love driving, even making deliveries for work, in my sparcos with my harness on. I feel very secure and have a much greater grasp of what the car is doing when driving kinda of hard around corners, offramps, etc. The setup does make you drive much faster so be careful if you do this on the street.. you never know what to expect... since it is an uncontrolled environment. I also enjoy being anchored in, whenever I am driving and my seat position plays a big role in what controls I can reach on the dash for daily driving ---> no glove box unless I unbuckle, but otherwise I am fine.
ZCHondaCRX91
Mar 15, 2011 07:30 AM
meheartmycivic
Sep 2, 2009 09:46 PM
ryanevansoh
10
Jul 20, 2009 04:50 PM
89efDUSTY
Apr 27, 2007 12:33 PM
teggytegteg
May 13, 2004 02:27 AM
