Broken Turbo Manfold
While driving through town today, not in boost at all, my car got much louder. I pulled over to see what happened and heard a scraping sound. Popped the hood and saw this:
My Tial wastegate dragging on the ground... Lame *** TurboXS weld snapped.
So now I have to buy a new one, any suggestions?
i cant believe that happend ............................................ lol
get it welded if your low budget
but i suppose u could always buy a better manifold
spoolin performance, AFI, peakboost, full race, lovefab, etc...
check out the FI sponsor's classified
http://hondamarketplace.com/search.php?searchid=2889367
I personally run a spoolin performance log and have had no problems with it as of yet. When i was b series i ran a pfab log and had no problems with it either. Which manifold you choose really depends on budget, hp goals, space etc., you will just have to look around and see what suits your setup best. Funny i had the same manifold break in the same place as yours did.
Buy a good manifold and you wont have to worry about anything breaking. Might trying checking out straightlinespecialties
http://straightlinespecialties.com/s...hp?cPath=23_31
My Tial wastegate dragging on the ground... Lame *** XS Power weld snapped.
Personally I would suggest spoolin performance. Log mani + downpipe + wastegate dumptube for 575, depending on the budget you have, as your downpipe might fit differently with a different style of manifold.
Bump for a local.
also be prepared that if you end up changing the manifold, you will need to change the dp, dump tube and possibly IC piping adding more costs.
again all of this could have been avoided in the first place with a quality mani
Buy a manifold from Spoolin Performance or Synapse Motorsport.
www.Synapseturbo.com
www.spoolinperformance.com
yep.. youll need to change the downpipe and dumptube to fix it .
you can get our quick4 manifold for 495$ but youll still need the new components listed above
Well I welded the manifold today, just until I can afford a new one. Plan on gettin a spoolin performance quick4 in the future, but until I have the money this will do. It's also heat wrapped now.
It's not the prettiest weld, but it will work.
