EK ex header + spring bolt broke off
I'm not much of an EK guy. Sorry for the ignorrance.
While changing my sisters ek CAT, I broke off both heads of the sprig/bolt.
1) is the bolt on the back of the header flange welded?
2) how do I take out the broken bolt?
a) cut it off with drehmel
b) heat it up and use a punch
c) use an impact gun to the back of the bolt?
TIA
TIA
you could allways buy some aftermarket headers.. thats what i did when mine broke off in the header. but im guessin a punch through the hole that the bolt went through should do the trick.
ej6kid
20
Oct 12, 2010 02:04 PM
Question to SMSP cat owners....what did you use to bolt the cat to the header...stock spring bolts d
jdmspoonitr
Nov 25, 2002 08:48 PM
