99 passenger side motor mount.
What does it take to get my 95 B16 tranny to mount up. The kid before me had a H22 in it. Is there some aftermarket part i need to buy or did he probably take a mount off?
You'd have to cut and reweld the mounting bracket back on. Well the mounting tabs for your stock b mount bolts that is. Also if he had an h swap in there, I'm not 100% sure but you'd have to change your shifter back to an actual linkage. Cut and weld there too! Because he had to weld in a new tranny bracket to get the h to fit and the shifted had to be changed to cable. I'm wrong here someone fix it for me. Other then that you'd be set to put your b series trans back in. You doing an h2b swap? Good lick and hope this helps.
I drew a picture on paint of what I have and what I need. I believe what I need is something that is bolt on. What I have is on the left, what I need is on the right.
