Jdm PR3 Head
Which manual can I source for service specs for a jdm pr3 head? I need to provide/check valve installed height and some info to the machine shop 'cuz they're v8 people and I don't think they'll even bother to look it up.
Can't find a downloadable itr manual. Will usdm del sol work, or which 'teg?
I can find a few on the sites that have pdf's avail., But they don't have everything. Thanks if u can help..I need to get this engine built SOON.
Yeah, that DelSol manual is hard to find online so far....I'll look again.
Valve adjustment specs aren't a problem...Valve installed height is used to determine if the valve job places the valves too deep in the head from machining. I'm re-using the stock valves.
I want to be able to print out some pages.
you might try http://www.hondahookup.com/manuals/ They have a lot pdf helms manuals. you have to sign up though.
Schister66
15
Dec 23, 2012 10:35 AM
DamonBoost
Sep 3, 2001 04:20 PM
