slight issue when changing upper arms
One of my friends and I redid the upper and lower ball joints on my car the other day. I used oem lower ball joints but replaced the upper arms with a Skunk2 Pro series camber kit. When I went to replace the knuckle protector, the castle nut on the ball pin turned out to to be larger diameter than the stock one and I can't put the protector back on. Any solutions or should I just slather it with grease and forget about it? I don't like to reuse hardware.
I coated both sides with white lithium grease. Would this be an acceptable alternative to the actual protector or should I figure some way to put the protector piece back on?
crxaddikt
Mar 15, 2006 08:13 PM
