Doors squeaking/grinding??
Old Jun 29, 2009 | 08:19 AM
skate1968's Avatar
Default Doors squeaking/grinding??
I have this odd problem. The rear driver side door squeaks when opening and closing. It's gotten worse. The rubbing seems to be coming from inside of the door -- maybe behind the door panel. The noise is coming somewhere from the sliding metal 'track' -- EDIT: the manual calls this the 'detent' rod -- the metal rod connecting the frame to the inside of the door -- the rod that runs horizontal and is located below the window -- the detent rod is located between the two 'hing mounting bolts' which bolt the door on to the frame.
Anyone ever get this problem?
I'm guessing that involes taking the door panels off and fixing somehow.
I'm hoping that it's not a sign of the frame rotting away. I'm hoping that it's not indicative of the frame weeping -- i've got a bit of rust but i'd like to think that it's relatively minor. I'd like to think that the rust is a cosmetic problem. (a body shop guy explained to me that the car was undercoated with a good protective coating so the undercarriage is good)
Eventually i'll take it to my mechanic and let him look at it.
Old Jun 29, 2009 | 09:01 AM
EL Vap133's Avatar
Default Re: Doors squeaking/grinding??
Maybe all you need is to grease the doors?
Old Jun 29, 2009 | 09:27 AM
skate1968's Avatar
EDTI: see updated version of original question
Thanks EL Vap133,
I tried that already. But it's worth trying again.
I was driving someone and he said it sounded as if it was more than your typical WD40 thing. Rather he said something like it being a case of "metal rubbing metal." He then named some kind of heavy duty lubricant as being something that might help.
The noise itself doesn't really bother me so much. But it's more a worry of what's causing it. If the frame is weeping then i won't bother doing the cosmetic work that i had planned.
Last edited by skate1968; Jun 29, 2009 at 09:57 AM. Reason: to elaborate and clarify
Old Jul 1, 2009 | 04:01 AM
skate1968's Avatar
Update:
Apparently this does seem to be a mere case of something rubbing/scraping/squeaking around the door area. After looking closer neither myself nor my mechanic believes it to be indicative of the frame weeping/sagging from it rotting out.
That seems to be part of the case. Except i might have to also address an area of metal that's rubbing the detent rod.
crx_si-r
23
Feb 7, 2010 05:20 PM
JdelMsolG
Jun 30, 2008 05:09 PM
cvcrcer
33
Jul 7, 2007 09:14 AM
GSRCRXsi
Dec 1, 2004 03:30 PM
