Reusing arp head studs
Is it ok to reuse the stud and nut after they were used for around 10k ? Is there a stretch limit ? What actually causes the bolts to stretch ? Is it re-torqeing the bolt that cause stretch or just the amount of pressure on it constantly while running ? How would you measure this ?
i think one of the main points for using ARP studs is so that you can re-use them... as for the service limit or max stretch allowed, i'd contact some one at ARP.
the stretching though is the point of torquing bolts and studs. when you torque the studs you're stretching them.. when you loosen them again, they return to there previous state. ARP studs are designed to do this over and over without un-loaded stretching or fatigue.
Also technically when the bolts are torqued they stretch but over a few times they should return to their previous state like you said. However will a bolt over time be unusable due to the forces of combustion on it ? Will that cause it to fatigue or stretch ?
a stretch gage is what you would use to measure the studs. this is the next level beyond using a torque wrench. i am unsure though how this would be done without being able to access the end of the stud...
you can measure before and after, maybe keeping a log of stud length over time and mileage. but you'll likely want to be looking at 0.001" variations, which means you'll need some pretty accurate measuring equipment.
i don't know engineering specifics for ARP, but i know they are presumably the best you can get and i know they've done their homework... i would speculate that their head studs don't even experience 10% of their yield strength in a running engine. you should be able to trust them for the life of the engine (...assuming this is not a dedicated competition engine- even then though, you shouldn't have any trouble.)
Last edited by hondamark35; Jun 29, 2009 at 08:34 AM. Reason: my grammar is terrible.
could you measure stretch from a fixed point such as the block deck ? Because stretch as far as a bolt being bad is measured without the bolt being torqued ? Since when using a rod bolt stretch gauge it is meaured while being torqued.
From: where i stunt SAND CANYON in Southern California
YES U CAN REUSE THEM ! and if u overtorq u might pull the threads out of ur block ! lol good luck with that budddy ! then u gotta pay like 30 - 70 a hole to fix hahah i fixed many !
i have no idea how threads like this go for soo long since it should be locked and deleted a long time ago.
or just get some new ARP lube
wildoutwhitegsr
18
Feb 17, 2006 07:09 AM
