Measuring for rod and main bolt stretch
Old Jun 28, 2009 | 08:51 PM
kornerk12's Avatar
Default Measuring for rod and main bolt stretch
I have a question that relates to measuring for oil clearance for main and rod bearings. I understand you are supposed to torque them to spec to measure for clearance on both rods and mains. However I thought main bolts as well as rod bolts were only supposed to be torqued one time ? Doesn't this stretch the bolts and when retorquing the bolt wouldn't it be inaccurate ? Or will the bolts go back to size ? How does this work when torquing using rod bolt stretch ?
Old Jul 1, 2009 | 01:16 PM
ZoRG's Avatar
Default Re: Measuring for rod and main bolt stretch
Bolt torques specs are actually low on engines compared to what it will take to actually stretch the bolt/stud, you'll be fine.
Old Jul 1, 2009 | 02:49 PM
kornerk12's Avatar
bump
Old Jul 1, 2009 | 03:54 PM
stumpyf4's Avatar
Some fasteners are designed for elastic region stress/strain (i.e. plastic region is where they don't take on any permanent stretch) like rod and main bolts and can be reused. Some are designed for plastic region stress/strain (i.e. do take on some permanent stretch) like head bolts and shouldn't be reused. Check the repair manual, if it says replace then most likely the fastener was a plastic region type bolt.
blackeg
Jun 6, 2015 03:40 AM
kornerk12
Jun 29, 2009 08:09 PM
tommyj
Apr 22, 2007 02:16 PM
GOLDBERG
Sep 5, 2003 03:04 AM
